Trelleborg Gimbal Mountings Selected for Ruhrpumpen’s Water Injection Package
LEICESTER, England (May 7, 2014) – The pump manufacturer Ruhrpumpen has chosen Trelleborg gimbal mountings for its water injection package for LNG in Gjerdrum, Norway. The package is placed on a special designed Floating Production, Storage and Offloading (FPSO) unit from Sevan Marine, the “Sevan Voyageur.”
Trelleborg’s gimbal mountings will be used as a three point suspension system protecting the equipment from vibration and the movements of the vessel. By reducing vibration, shock and structure-borne noise, isolation systems make an important contribution to protecting high value installations, improving efficiency, safety and the working environment.
The water injection package from Ruhrpumpen consists of two booster pumps type SCE 10X8X16 and two main pumps at SM 6X13X10. The main pump skid, that also will carry the Lube Oil System, has been designed as a three point support version, which is a special design for platforms and FPSOs.
Trelleborg provides engineered polymer solutions that seal, damp and protect critical applications in demanding environments.
Cahaba Media Group
See also:
Upstream Pumping
