The future of desalination will require a combination of experienced-based design and environmentally friendly technologies.
by Boaz Keinan
Today’s reverse osmosis (RO) plant design is based on diverse technological knowledge and, just as importantly, on operational experience, which can be a valuable asset for design teams. For desalination plants, it is important to explore a methodology for bridging between operation and maintenance (O&M) experience and design, while finding the process design of the future.
O&M teams can gain operational experience through daily work of performance monitoring and overcoming challenges. Typical objectives of the operation team include improving plant performance, correcting malfunctions, boosting compliance with new regulations and reducing operational costs.
Carlsbad Desalination PlantImage 1. High-pressure seawater is pressed through millions of square feet of spiral-wound reverse-osmosis membranes at the Carlsbad Desalination Plant in Southern California. (Image courtesy of Poseidon Water)
Methods of harnessing operational experience and turning it into valuable design knowledge for desalination plants include:
  • periodic meetings focused on sharing knowledge between O&M companies and design engineers
  • on-site piloting, which allows technical interaction between the O&M team and the design engineers
  • monthly reports issued by the O&M managers
  • providing technical and process support to the operation team as required
  • inviting lead technologists and operation managers to participate in design review meetings
Taking operational experience into consideration does not mean that the RO plant is overplanned. Sometimes a small investment can make a big difference and lead to better results for the plant.
Operational experience can help prevent execution and startup difficulties. The following shows real-world examples of incorporating operational experience into design knowledge.
Optimization to Reduce O&M Cost
The design team should learn the RO plant’s behavior from the O&M personnel and optimize the design accordingly. For example, the chemical consumption can be reduced through improvements and optimizations performed during O&M.
At the Ashkelon Desalination Plant in Israel, the second pass chemical consumption of caustic soda and sulfuric acid were optimized through day-to-day monitoring of the performance parameters such as actual boron rejection, membrane-feed pressure and normalized flow. Ferric chloride consumption was optimized through monitoring of pretreatment performances and by using improved control methods.
Sorek Desalination PlantImage 2. The 16-inch membrane vertical layout at Israel’s Sorek Desalination Plant, the world’s largest seawater reverse osmosis desalination plant (Image courtesy of IDE Technologies)
Another parameter to improve is the plant’s specific energy consumption. Although specific energy consumption should increase as the RO membranes age, the O&M team at Ashkelon successfully maintains guaranteed energy consumption and, in some cases, improves the plant’s specific energy. In this case, the O&M teams reduced energy consumption by replacing a valve internal part, which created a high pressure drop, and by developing methods and procedures for maintaining RO membranes’ performance by rotation of the membranes with the pressure vessel. The real behavior of the plant, including actual pressure drops and energy consumption, can help optimize future designs.
Equipment Failure
One method of improving design is by studying equipment failures together with the O&M team and providing technical support until a solution is found. During the first operation period in the Hadera Desalination Plant in Israel, the media filter’s flap valves suffered from leakage. A new mechanism based on hydraulic pistons was developed, including reinforcement of the shafts and improvement of the rubber sealing.
The hydraulic mechanism was first piloted and then implemented successfully in full scale.
The experience from Hadera and the upgraded solution has been used in some later designed RO plants, such as in the Vasilikos Desalination Plant in Cyprus and Carlsbad Desalination Plant in Southern California.
Optimization of Control & Automatic Sequencing
An example of how optimizing control and automatic sequencing can lead to design upgrades involved leakage from high-pressure (HP) valves isolating the RO train identified in the Hadera plant.
Following a thorough investigation, the O&M team improved the startup and pressurization sequence so the pressurization occurred in a gradual manner, preventing sheer forces on the isolation valve’s Teflon sleeve. This modification proved successful and the experience was transferred to some other plants working with pressure center.
Construction Materials
The O&M team gains significant experience and knowledge of what material is resistant and what should not be used. The chemical line insulation and heating provision were added for chemicals with a high freezing point (such as NaOH lines) in the Ashkelon plant.
The sulfuric acid injection assemblies, which suffered from many leaks because of the exothermic conditions existing in the injection point, were replaced with a Teflon-coated steel type. This robust solution was then added to future designs.
Additional coatings for concrete, steel and pumps were implemented by the O&M teams. The team, with the support of the design team, implemented a cathode protection system for the metal pipes and pumps. Some of these lessons, already learned during the design stage, will cost less in the overall plant life cycle.
Pages
