American municipalities face aging infrastructure problems in almost every aspect of their services to citizens, including roadways, electrical distribution, water and sewer distribution, and collection and treatment processes.
Variable frequency pumping equipment in treatment plants and pumping stations can be especially vulnerable to early failure as a result of the repair-or-replace dilemma. Repairs may be impractical because of obsolescence on the part of the component manufacturers or equipment manufacturers.
A recent survey of more than 200 water and wastewater professionals reveals that this is a concern in their industries. More than 75 percent of respondents reported that aging infrastructure issues have affected their plant's performance, breakdown frequency or capital equipment budgets (see Figure 1).
Pumps and the electric motors that drive them are generally recognized to be reliable and long-lived (see Figure 2). But expectations and experience indicate that some variable frequency drives (VFDs) may not live up to the life expectancy of their related driven equipment (see Figure 3).
Recognizing this weak link in the reliability and ownership cost of variable speed pumping equipment, many specifiers and users have shown an interest in alternatives to VFDs (see Figure 4).
Eddy current drive technology has been used since its development in the 1930s. In the 1960s and 1970s, the eddy current variable speed drive was a common choice when variable speed pumps or fans were needed. End users installed thousands of such units in applications in several industries, including water and wastewater treatment, booster stations, and lift stations.
Eddy current drive technology can be a reliable alternative to some other VFDs. An eddy current drive controls speed by regulating a direct-current (DC) excitation coil on a magnetic rotor, rotating concentrically with a steel drum, driven by the motor at full speed. Like the pumps and electric motors that drive them, eddy current drives are rotating machines. They are constructed with steel castings, fabrications, bearings and electrical windings. Most maintenance and repair personnel can easily understand these drives, which have wear parts readily available at a reasonable cost. For these reasons, eddy current drives are found in active service up to 50 years after their installation.
In the 1980s, it became popular to replace existing eddy current equipment (even when fully operational) with VFDs, which were seen as a more modern and efficient system. In some cases, this idea was shown to be misguided, considering the cost to repair or replace VFDs that fail before the pump and motor reach the end of their useful life. This can be the case for large-horsepower applications that require medium-voltage (2,300- or 4,160-volt) motors. VFDs in these applications are large, expensive and often require space added on to existing buildings that must be equipped with air-conditioning systems that consume more power.
Recognizing these factors, some users and specifiers are taking a new look at the old technology of eddy current drives. Existing units in need of repair are being replaced with new units or rebuilt to factory specifications that will restore them for decades of continued service.
