The major focus of any industrial distributor should be maintenance. The distributor's personnel work daily with maintenance mechanics, plant engineers, maintenance managers and all those working to keep plants running. The work of these key people affects the overall efficiency, reliability and longevity of their liquid transfer process equipment and systems. These employees have often inherited the equipment, and their responsibility is to keep it working day in and day out. While this may seem simple, maintenance must be approached from the perspective of the plant floor—not just from the chair of the design engineer. The best designs are a combination of thoughts from the technician to the senior engineer.
Getting Started
The first step to achieving optimum efficiency is to define it. Is it simply energy savings? Or is it reliability, uptime, product longevity, reduced maintenance time and costs, and product standardization? Efficiency consists of all of these elements and more. To realize optimal performance from the plant floor, all personnel must understand five key factors affecting efficiency.1. The equipment must be correct for the application.
In the middle of the night during the stress of a breakdown, the maintenance employee will do what he must to get the equipment operational—including using something other than the original part. Changes of this nature are surprisingly common. Even though changes are made daily, they are not always recorded, and best paperwork practices are not always followed. Distributors must rely on a user's information to supply the correct product. If accurate records are not kept, the possibility of receiving the wrong product increases. For these reasons, keeping accurate records is critical. Many pumps are on their second or third application. They may be from a closed plant or a discontinued process, and they find their way to the boneyard to be used at a later time for another application. Repurposed pumps are used primarily because of their convenience; they are paid for and readily available. Before reusing a pump in this manner, however, users should question if it is, in fact, the correct product for that specific application. Misapplied pumps typically require a significant amount of replacement parts and related labor, time and costs and may result in downtime. To avoid this pitfall, users should find out if the requirements have changed since the initial installation. They can check items such as viscosity, pH factor, temperature, product being conveyed, available net positive suction head (NPSH), type of supply, discharge pressure requirements and piping changes.2. The efficiency of the pumping system is impacted by the piping design layout.
Answers to the following questions and subsequent corrective action will help ensure maximum efficiency from the unit.- Does the piping schematic allow for the best efficiency?
 - Are the velocities within the recommended standards?
 - Has the number of Ls (elbows), Ts, Ys and miscellaneous fittings been minimized?
 - Are the valves correctly applied and kept to a minimum?
 - Are the correct fittings being used (e.g., eccentric versus concentric reducers)?
 - Is the piping in good condition? Buildup of corrosion and wear can result in higher resistance to flow.
 - Are the fittings, valves, etc., mounted no closer than the minimum distance from the pump as required?
 - Is the pump located in the best location to minimize the runs and all twists and turns?
 - Are valves being used to control flow instead of sizing the pump for the duty points?
Image 1. An example of an inlet eccentric reducer with the taper to the bottom and a discharge concentric reducer (Images courtesy of Motion Industries)3.The pump must be in top condition for maximum efficiency.
Many factors affect the efficiency of the pump, such as imbalance of the impeller, incorrect size of impeller, coupling misalignment, incorrect parts or lubrication, and worn parts, which could include bearings, casings, wear rings, impellers and rotors. One of the best ways to avoid problems is to catch them early with scheduled, preventive maintenance.4. A properly sized motor in new condition is essential.
Could the motor have been replaced with a different one during a breakdown? Has the motor lost efficiency? This is another example of the importance of using the correct equipment. Too much horsepower or too little horsepower will result in inefficiency.5. Monitoring the pump and system is vital for long-term success.
Inlet and discharge pressure gauges are inexpensive and can give a good indication of how the system is performing. Users should set the pointer on the inlet gauge for the required NPSH and on the outlet gauge for required discharge pressure. Vibration analysis is another great tool to track pump operation and efficiency. A good distributor's specialist looks beyond the symptom to define the problem's root cause instead of offering a quick fix. When looking out for the user's welfare, the specialist's focus should not be on selling but on troubleshooting and providing corrective measures. This approach will bring value to the plant floor by reducing their overall cost of ownership, suggesting methods or designs to improve efficiency and helping to ensure productivity.How One Plant Saved Thousands in Repairs & Replacement
Correct equipment selection and application can provide an efficient and reliable pump and system. In the following case, a distributor's pump specialist assisted a user, a major producer of extruded aluminum, with a solution that led to $36,000 in savings.
The Root of the Problem
The aluminum producer needed to solve the problem of shortened life of their 6x6 vertical pumps. The pumps, used for an acid wash on their paint line, were lasting only six to eight months. After that, volute and impeller failure would occur. A quick observation showed the problem. The pump was not mounted deep enough in the tank to keep the liquid from vortexing and causing cavitation to the pump.
Because of this, the 1 percent sulfuric acid the user was pumping was at a velocity far too high for the depth of the bell housing of the pump. The fluid should have been moving at about 3.25 feet per second but was moving more than four times as fast at 14.76 feet per second. The lower velocity would prevent the pump from vortexing at the pump's immersion depth. Immersing the pump lower would have stopped the vortex and prevented inevitable failure immediately.
Lowering the pump, however, posed a problem. At the current velocity, the pump would need to be immersed to 13.5 feet. The tank was only 44 inches deep.
Luckily, immersion depth was not the only way to correct the problem and prevent constant maintenance issues. The pump was also incorrectly mounted, which was quickly corrected.
The distributor's pump specialist determined a simple fix by placing a stainless steel plate above the bell housing of the pump to act as a vortex breaker. This plate would correct both the vortexing and the entire system. The specialist calculated the required size of the plate, the user made it to his specifications, and the plate was immediately attached.
A Long-Lasting Solution
At one time, this plant's $10,000 pumps needed repairs costing at least $2,000 every 30 to 45 days, with a complete replacement of the pump every six to eight months costing $10,000 to $12,000. Since the problem was corrected with the distributor's help, the pump has operated for two years without further maintenance or repairs—resulting in approximately $36,000 in savings since implementation.
