6 Key Considerations When Selecting a New Pump
Choose the right pump to safeguard uptime, enhance sustainability and deliver measurable value.
ITT Goulds Pumps
Selecting a pump may seem straightforward, but it is more than simply choosing a piece of equipment: It is making a long-term investment in the reliability, efficiency and sustainability of an operation. Pumps are among the most critical pieces of rotating equipment in any facility, but they are also a significant expense. A decision made hastily or based solely on the lowest cost can create years of maintenance headaches, while a well-informed choice can lower energy consumption, extend service life and reduce total life cycle costs.
Here are six factors every engineer, operator or maintenance leader should keep in mind when looking for a new pump.
1. Understand Fluid & Process Conditions
The first step in pump selection is not to look at catalogs or specification sheets, but to take a hard look at the fluid being moved. The characteristics of that fluid dictate nearly every aspect of pump design, from the hydraulics to the metallurgy. For example, clean water presents different challenges than abrasive slurries or corrosive chemicals. A pump that performs perfectly in one service may fail prematurely in another if the materials are not right for the environment.
The chemistry of the fluid matters to the selected pump design. Corrosive liquids may require higher alloy materials or engineered coatings on the pump that resist degradation over time. While these options carry a higher initial price, they can eliminate repeated recoating or replacement later, which often makes them the more cost-effective choice.
Similarly, when fluids contain solids or are particularly viscous, pumps must be designed to resist wear. Features such as replaceable wear rings or hardened surfaces can protect the pump casing and impeller, extending the equipment’s useful life. Temperature and pressure must also be considered, since extreme or fluctuating operating conditions put additional demands on seals, bearings and materials.
IMAGE 1: Greater pump efficiency can result in substantial savings over decades of operation. (Images courtesy of ITT)
2. Think Beyond Flow & Head: Efficiency & Life Cycle Costs
When engineers compare pumps, they often focus on flow rate and head pressure. These are important parameters, but they only tell part of the story. A more holistic view also accounts for efficiency, repair economics and overall life cycle costs.
Energy use is usually the largest contributor to a pump’s total cost of ownership. Even small improvements in efficiency can result in substantial savings over decades of operation. Beyond efficiency, it is also necessary to think about how the pump will be repaired and maintained. Some designs allow critical components such as wear rings or shaft sleeves to be replaced easily, which can prevent the need for costly casing or shaft replacements.
Service intervals are another key consideration. Pumps engineered for longer mean time between repairs reduce the frequency of shutdowns and the labor costs associated with maintenance. When procurement decisions weigh only the initial purchase price, these long-term savings are often overlooked. A pump that costs more up front may ultimately be the more economical choice when viewed over its full-service life.
3. Select the Right Materials & Protective Options
The materials chosen for a pump can determine whether it lasts a few years or several decades. In some cases, standard materials may be fine, but in harsher applications, higher alloys or specially engineered coatings are needed. These materials resist corrosion and wear, preventing premature failures. Although they add to the upfront expense, the investment often pays for itself by eliminating frequent repairs.
Another way to extend pump life is through protective features like hardfacing, where an extremely hard layer is applied to wear surfaces. Hardfacing on rings or sleeves can dramatically improve service life in abrasive applications, although it must be selected carefully to ensure compatibility with the pumped fluid.
Sacrificial components, such as shaft sleeves, also play a valuable role. By absorbing wear that would otherwise damage the more expensive shaft, these sleeves protect critical equipment and reduce repair costs. In vertical pumps, similar principles apply to lineshaft sleeves, which guard against wear at column bearing locations.
4. Optimize Control & Operating Speed
How a pump is operated can be just as important as how it is built. Variable speed control has become a mainstay in pumping applications because it allows for process flexibility and improved energy efficiency.
Operating speed itself is another big factor. A pump running at higher speeds may be cheaper to purchase, since it can deliver the required flow and head from a smaller package. However, higher speeds often accelerate wear, leading to more frequent and costly repairs. Lower-running pumps may be larger and more expensive initially, but they typically last longer and operate with less wear and tear. Balancing these trade-offs requires both an understanding of process requirements and a long-term view of life cycle costs.
5. Protect Seal & Bearing Reliability
Seals and bearings are often the first points of failure in a pump system, which means they deserve special attention during selection. Seal chamber design plays a major role in performance. Options such as big bore or tapered bore chambers can improve flexibility and extend the life of seals in different operating environments. For especially demanding applications, seal configurations that comply with recognized industry standards and incorporate engineered flush plans can further reduce leakage and extend operating life.
Bearings are equally important. Misalignment, poor lubrication or inadequate bearing protection can quickly lead to costly failures. Selecting pumps designed with robust bearing systems—and pairing them with sound alignment and lubrication practices—is one of the most reliable ways to reduce downtime and ensure long-term service.
6. Plan for Support & Service Over the Long Term
A pump is not just a product, but a system that requires ongoing support. Having reliable access to spare parts, service expertise and training can make the difference between smooth operation and costly downtime. When evaluating suppliers, it is worth considering not just the product itself but also the ecosystem
of support that surrounds it. Are spare parts readily available? Is technical expertise accessible when problems arise? Are there opportunities for training to help operators and maintenance teams install, operate and maintain pumps more effectively?
These questions may seem secondary at the time of purchase, but they can determine whether a pump remains a dependable asset over many years or becomes a persistent source of problems.
IMAGE 2: A reliable pump designed with repairability in mind can save money and downtime throughout its lifetime.
Choosing Thoughtfully for the Operation
The best pump is not necessarily the cheapest or the one that meets only the minimum specifications. It is the pump that balances process requirements, efficiency, reliability and long-term economics. By focusing on fluid conditions, life cycle costs, materials, control strategies, sealing and bearing reliability and the long-term service picture, end users can make the choice that is smartest for their operation.
The right pump, chosen intentionally, does more than move fluid. It safeguards uptime, enhances sustainability and delivers measurable value across the life of an operation.
For more on pump selection, visit pumpsandsystems.com/tags/pump-selection.
