There are many stories of expensive pump repairs and performance problems brought on by cavitation. In one case, a municipal water department was replacing impellers for its reservoir feed valve every 18 months, for years, until engineering efforts produced an accurate diagnosis and resolution. In another instance, a power plant was regularly forced to spend millions of dollars to shut down, dismantle, transport, repair and re-install cooling water pumps before it understood the root problem and an effective remedy. If high cost is not a serious enough issue, there have also been reports of pumps exploding and motors flying through concrete walls, which suggests that someone could be seriously injured or even killed by the effects of cavitation.
Image 1. Impeller damage shown with a pump performance map (Images courtesy of Armstrong Fluid Technology)System Performance
Well before equipment runs to failure, cavitation can quietly ravage an operating budget. Cavitation reduces flow performance, which can lead to increased power consumption, and can cause serious wear on seals and bearings. Associated noise can create occupant reactions and even minor leaks can cause unwanted cleanup expenses. Writing in Pumps & Systems a year ago, Jim Elsey noted that, “When the bubbles collapse near or at the metal surface, they collapse asymmetrically and cause a small microjet. This collapse occurs on a nanoscale (1.0 x 10-9 or billionth). Local pressure forces involved can be higher than 10,000 pounds per square inch gauge (psig) (689 bar) or more, plus there is heat generated. “This phenomenon can occur at frequencies up to 300 times per second and at speeds near the speed of sound.”It Is Complicated
Occasionally, journal articles from a variety of experts appear, presenting structured breakdowns of the types of cavitation damage, their causes and solutions. Meanwhile, the average engineer acknowledges that cavitation is not simple to diagnose, and often even more difficult to correct. In the “Centrifugal Pump User’s Guidebook: Problems and Solutions,” published in 2012, Appendix A contains a checklist of pump problems and their causes. Under “Pump is operating with noise or vibrations, or both” it mentions cavitation, plus 41 other possible explanations. It is true that symptoms indicating cavitation might also signal air entrapment, suction recirculation or discharge recirculation. It can be expensive to determine the problem, before any consideration is given to the cost of solving it via shutdown, draining the system, service personnel, redesign, new components, downtime and more. The good news is that technology has evolved to provide more precise information.
Image 2. Fluid management data monitoring and analytics can predict pump problems
