Keep facilities up and running with simple, proven solutions for these critical assets.
John Crane
12/05/2018
The Pumps & Systems editorial staff receives many reader requests for articles on pump fundamentals. What follows is a series of answers to questions about boiler feedwater pump basics, why these pumps are important and more.
Pumps & Systems: What is a boiler feedwater pump
John Morton: Industrial power generation is important, and demand is growing. And at the heart of any power station’s pre-boiler system is the boiler feed pump. Most of these pumps are between-bearings, multistage centrifugal designs with mechanical seals installed at each end of the pump. Boiler feedwater pumps are used to increase the discharge pressure of the feedwater to the boiler. Boiler feed pumps serve to feed a steam generator such as a boiler or a nuclear reactor with a quantity of feedwater that corresponds to the quantity of steam emitted. To deliver the feedwater into the boiler steam drum, the boiler feed pump has to raise the pressure beyond the boiler steam drum pressure.P&S: Why are these pumps important?
JM: Boiler feed pumps are critical assets to steam plants, and keeping them up and running is paramount to plant operations. These pumps must be reliable—rugged—to withstand continuous high pressure pumping operation and be suitable to cope with additional variable conditions. For example, the changing of water quality during operations has the potential to impact pump performance, especially if using a cooler on the pump.
Image 1. API piping Plan 23 is often the go-to solution for keeping a boiler feedwater pump running. (Images courtesy of John Crane)
