While manufacturers claim these wipes are flushable, they have been causing major problems for wastewater facilities, and the problem has only worsened in recent years. New York City alone claims that more than $18 million has been spent during the past five years to remedy wipe-related problems in their 14 wastewater treatment plants. In the Southwest, a Tucson, Arizona-based news crew visited a regional reclamation center and documented that "white wipes were everywhere." The operator suspects the wipes are not biodegrading as fast as the general public is being led to believe. The wipes cake the walls and eventually get stuck in the sewers where they clog pumps and pipes. When blockages occur, there is just one way to clear them—by hand.
Facing the Problem
Several pump companies have attacked the problem by developing equipment that will shred wipes and other solids to make them safe for wastewater systems. The engineers at one company have developed dual shredding technology that features radial and axial shredding elements. This design obliterates wipes and other hard-to-handle solids. "Incorporating both radial shredding and axial cutting achieves optimum results on hard, to near impossible to pump liquids containing fibrous solids like wet wipes," said Brian Mitsch, the company's VP of operations and engineering. "The radial shredding is achieved by a rotating cutter bar with serrated edges, which traps and shreds solids against the sharp grooves of the radial cutting ring. Wipes and other fibrous debris are efficiently ripped apart. The complementary axial cutting utilizes dual cutting elements operating in tandem to multiply the shearing action. As the material exits the radial shredding area, the axial cutting components shear any remaining pieces using multiple cutting bars. The impeller design expedites flow and hydraulic performance, preventing wrapping and clogging." These pumps feature shredding elements that are cast in hardened 440C stainless steel (Rockwell hardness above 55C), and the patent-pending design provides excellent solids-passage efficiency through its impeller and volute. Available with 2-, 3- or 5-horsepower (HP) high-torque four-pole motors, these pumps are ideal for smaller wastewater stations.
Case Study
FoxRock Properties owns and operates two massive office and medical complexes in Norwell, Massachusetts. The first of the neighboring properties is Longwater Place, a 27,000-square-foot office building, part of a larger 26-acre campus that includes 84,000 square feet of corporate offices and a 160,000-square-foot wellness center. Longwater Place incorporates a full cafeteria, and fitness center, featuring a gymnasium with squash courts and locker/shower facilities. The adjoining property is South Shore Medical Center, an 85,000-square-foot facility comprised of 100 medical examination rooms, 70 medical offices and a complete range of diagnostic equipment.
