Countries in the Middle East and North Africa (MENA) have always been prominent food importers rather than producers. The punishing climate and topography have challenged efforts to expand the region’s food-processing indus- try, especially in countries belonging to the Gulf Cooperation Council (GCC). Now, after decades of steadily increasing activity, the MENA food market can expect to exceed 1 trillion U.S. dollars by 2030, according to the World Bank. Rapid population growth, booming food service and re-export markets, and diverse customers looking for new tastes have ignited this rising demand. The MENA food industry is now flourishing, and many of the world’s leading food and beverage manufacturers have begun locating operations in the MENA region.
Lower Costs, Higher Yields
Food and beverage manufacturers in MENA countries face the same challenges as those in the rest of the world—maximizing product yields while optimizing operational costs. Tight budgets have forced plant operators to meet production goals while spending less money. While energy costs are often low in the MENA region, raw materials for food and beverage processing can come at a premium.
Energy vs. Product Recovery
Energy efficiency is one way to save operating costs, but for food and beverage manufacturers, energy alone will not deliver significant savings. Figure 1 shows how much money is consumed and potentially saved, per positive displacement pump, if the cost for energy is US$0.10 per kilowatt-hour (kwh).
Figure 1. Power consumption saved per positive displacement pump
Figure 2. Product-recovery cost savings per eccentric disc pumpEccentric Disc Advantage
In an eccentric disc pump, a disc moves on an eccentric plane within a circular channel. The pump provides non-pulsing, low-slip operation with high volumetric consistency. Flow rates vary minimally with changes in viscosity, temperature, system back-pressure and component wear. Specific designs can pump air even when no fluid is present. This creates a vacuum effect on the pump’s suction side and a compressor effect on the discharge side. Once the feed tank is empty, the eccentric disc design continues to pump air in a constant, non-abrupt, non-pulsating manner. Any remaining fluid keeps its surface tension, producing a “plug” effect that pushes out the product as a whole. Eccentric disc pumps can typically recover 95 percent of product on the pump’s suction side and between 60 and 80 percent or more on the discharge side.
Figure 3. Typical pump technologies used in hygienic applications. Click to enlarge.Extended Product Recovery
Eccentric disc pumps recover product from hard-to-reach stages in the food and beverage manufacturing process. These stages pose challenges for traditional process pumps or product-recovery methods, especially where projectile recovery is dangerous or impossible:- Tank bottoms, inlet and outlet lines
 - Hoses
 - Small-diameter lines
 - Transfer lines, including ordinary valves, heat exchangers, magnetic traps and flow meters
Additional Savings
This technology can also eliminate other costs. When transfer pumps inadequately strip suction or discharge production lines, the ancillary costs incurred by the facility operator worsen:- More water to clean the lines
 - Additional cleaning and treatment chemicals to clean the lines
 - Sanitizing chemicals to disinfect the lines
 - Energy to facilitate the cleaning process
 - Labor costs and hours to perform longer cleaning operations
 - Disposal costs of used water, chemicals and product
 - Water treatment costs and associated treatment chemicals
Time to Upgrade
Lobe, external circumferential piston (ECP), centrifugal, hose and progressive cavity pumps have been the go-to technologies in hygienic manufacturing processes for many years. While these technologies perform the basic pumping task because of their design and operating principles, they cannot adequately strip suction or discharge lines. This limitation is critical to the food and beverage industry, where the same pump may be used to transfer different products in a hygienic operation. Traditional pumps wear constantly. Internal clearances grow with time, resulting in product slip. This reduces flow capacity and volumetric efficiency as operating pressures and fluid viscosities vary.
Eccentric disc pumps recover food and beverage products from suction and discharge lines, where these products can be lost during changeovers or at the end of production runs.
A Growing Market
Food and beverage processing operators in the MENA region should, in addition to optimizing energy costs, target product recovery as an effective cost-saving tool. By design, eccentric disc pumps have the technological advantages that recover product as they transfer raw materials or finished product through suction and discharge lines. Thoughtful operators and end-users will capitalize on the MENA region’s food and beverage market growth by considering how they can save money and deliver quality goods to their customers at home and throughout the world. A version of this article originally appeared in the June 2014 issue of Pumps & Systems.The MENA Food Market
50: The percentage of MENA food that is imported
90: The percentage of GCC food that is imported, where Saudi Arabia imports the least (80) and Qatar the most (97)
1 trillion: The worth, in U.S. dollars, of the MENA food market by 2030
Source: The World Bank
