Considering what livestock will eat helps highly reliable slurry pumps remain in the pit longer.
09/17/2014
Pump manufacturers know that the engineering phrase “fit and forget” never holds true for rotating equipment. For all its reliability and longevity, a slurry pump that has been operating in a pit for several years will eventually fail. Several pumps can handle farming applications at a tenth of the initial cost for an application-specific slurry pump. However, replacing a cheaper, less effective pump every six months becomes a tiresome—and expensive—hassle for many farmers. This article features several examples of how selecting the right pump ensured worry-free operation in harsh pit service.
Two Decades Without Failures
Wholly submerged in slurry, the two 18.5-kilowatt (kW) pumps at J.E. Carter & Sons were built to handle thick and highly corrosive fluids. The 15-kW mixers, designed with a two-blade clogging free propeller, benefited from a double mechanical sealing system between the electric motor and the surrounding liquid. A J.E. Carter & Sons pig farmer requested maintenance on his slurry pump, which was installed in 1993. Chris Carter, a farmer at Strathyre Farm near Preston in northwestern England, said that his slurry pumps saw the daylight for the first time after 21 years of submersion. Carter used the equipment to transfer pig slurry from one pit to another—and then to a 20-foot-high store.
The slurry pumps at J.E. Carter & Sons farm handle thick and highly corrosive fluids. They are wholly submerged. A double mechanical sealing system protects the electric motor from the surrounding liquid.Determining the Slurry Content
Engineers can easily under- or over-specify pumps when handling cow slurry. Carrying out a proper evaluation is critical because the content of slurry pits will vary depending on what a farmer’s cows eat. Lucerne (alfalfa), grass or maize silage will have a higher viscosity than green or cereal crops. Rainwater and yard water also come into play, as well as whether the cows are kept indoors or outdoors. Thick, raw cow slurry is unforgiving. If slurry is mixed improperly, then the water will be removed, leaving all the solids. Farms often add pumps when their existing equipment cannot handle their slurry. Either their equipment is under-specified, or the pipe diameter and/or pipe work has been inadequate. Pipe diameter and pressure are crucial. Small pipe diameters need more pressure to move the slurry, leading a bigger, more powerful pump to do a job better suited to one half its size. Too big a pipe diameter can result in not enough velocity. Farmers do not need to use the pit’s entire volume for pumping.
Pipe diameter and pressure are crucial to a slurry pump system. Too small of a diameter requires more pressure; too large reduces the liquid’s velocity.
The knife system in a chopper pump can break down farm-related debris, such as aprons, rubber gloves and tail hair. Consistent, Even Mixes
Poor mixing and a lack of aeration in a field are easily detected. A stars-and-stripes pattern on a field (dark green and light green) means slurry has been incorrectly treated. The slurry should filter down into the ground and out of sight, fertilizing the land and crops.
The pressure in a slurry pump system must be high enough to carry slurry across great distances to a storage tank or pond.
The content of farm slurry will change over time depending on the diet of livestock and the farm’s debris.
