Chemical applications operate best with systems that offer strong corrosion resistance.
11/19/2015
Toll chemical manufacturing is an arrangement where a company manufactures or blends proprietary chemical products for other companies. The liquids and powders find uses in as-is finished products, food or drug nutrients, additives, coloring agents, catalysts, film coatings and special products for almost any industry. These specialty chemical manufacturers are typically small- to medium-size plants that produce on slim profit margins in a competitive market. Their engineering and maintenance resources are stretched. The following shows how a sealless magnetic drive pump saved downtime and maintenance on a troublesome fume scrubber application.
The Problem
In this application, the company manufactures specialty chemical products in batches of up to 5,000 gallons using 37 percent hydrochloric acid (HCL) as a concentrated base reactant solution. Some of the reactions are endothermic, and some are exothermic. When using the acid in a reactor, HCL fumes are often generated and emitted. The manufacturer had installed a fume scrubber using water as the scrubbing medium. The water is sprayed into a column packed with a plastic fibrous material. A centrifugal blower takes emissions from the vessel and blows them through the column. As the HCL vapors meet the moisture from the water, they are absorbed and the clean air is released (see Figure 1).
Figure 1. Example of a typical air scrubber (Images and graphics courtesy of IWAKI America)Open Seal Face
The major contributor to a seal face opening is shaft movement, which can be either axial, radial or due to vibration. Axial movement is usually associated with varying pump operation during startup, shutdown or valves opening and closing. It can also be associated with temperature changes during process cycles or batches. Sealless pumps use high-strength magnets coupled with thrust surfaces designed for varying pump operation. They also use materials designed for varying temperatures. Radial movement is associated with end play or shaft deflection when the pump runs past its best efficiency point. It is common when bearing frames wear and shaft deflection occurs. Sealless pumps are designed for full curve operation typically using dual thrust surfaces, and many of them are close-coupled, eliminating shaft-deflection risk. Vibration is usually found during cavitation periods when net positive suction head available is low or the pump is vortexing fluid from a supply tank. Sealless pumps typically using dual thrust surfaces are designed to handle moderate cavitation.Heat Generation
Heat generation is often associated with dry-run conditions or prolonged cavitation. It can damage seal faces and elastomers, causing them to fail and degrade lower-grade seal materials. Many sealless pumps have dry-run sensors built into or around the pump to alert operators of such a condition. Some designs even have patented bearings that withstand dry-run conditions. Almost all sealless pumps have dual-thrust surfaces designed to handle moderate cavitation.
Image 1. Two pumps provide a run/spare scenario because a pump failure could place the company in violation of stringent emission standards.
