STAMP Couplings
MAX Industrial Solutions
03/09/2018
SIZE:
What is the minimum outside diameter required for the pump to operate efficiently? Properly sized couplings prevent pump cavitation and increased temperatures under high workloads.TEMPERATURE:
What is the maximum operating temperature? Coupling materials can degrade under extreme pressures. Always make sure to pair the right coupling to the maximum operating temperature of the system.
APPLICATION:
What application will the coupling will be installed in? Will the coupling system need to be detachable? Is there a high level of vibration or pressure impulse that may cause the coupling to wear out prematurely?
MEDIA:
What type of fluid will the coupling be exposed to? Certain volatile chemicals can cause complete failure of a coupling system in a very short amount of time. Always make sure to verify the media being transferred with the manufacturer’s chemical compatibility chart.
