How Flow Meters Benefit Brewery Efficiency
Applications, requirements and types of flow meters used in beer brewing.
Tameson
What Is a Flow Meter?
A flow meter measures the amount of liquid or gas passing through a pipeline over a specific period. It provides essential insights into fluid movement within pipes, drainage systems and various infrastructure types. This information is invaluable for operators, as it helps verify system balance, ensure appropriate supply to each endpoint and detect excessive flow rates that could damage pipes. In essence, flow meters are critical for maintaining the efficiency and safety of fluid transport systems.
In some cases, regulating flow may be necessary. This can be achieved by combining a flow meter with a valve to create a flow controller. This setup measures flow and allows for adjusting the flow rate.
Modern flow meters often include electronic interfaces that provide real-time digital readings. They can connect to software systems for data analysis and recordkeeping, enhancing their utility in complex operations.
IMAGE 1: SAW flow meter made of stainless steel (Images courtesy of Tameson)
Why Are Flow Meters Used?
Flow meters are essential tools across various industries for several reasons:
  • Safety: They help maintain necessary flow rates, such as in industrial process cooling systems, preventing overheating and ensuring safe operation.
  • Leak detection: By measuring flow rates at different points in a system, flow meters can identify discrepancies that may indicate leaks.
  • Monitoring: Flow meters enable operators to ensure systems run efficiently and effectively, optimizing performance and reducing waste.
  • Billing: Accurate flow measurements are crucial for billing, especially in utilities like water and gas, where users are charged based on usage.
  • Environmental compliance: They measure emissions and waste entering the environment, helping organizations stay within regulatory limits and reduce their environmental impact.
Flow Meter Applications in Beer Brewing
Flow meters play a vital role in the beer brewing process by providing precise measurements of fluid flow rates, which are essential for maintaining consistency, efficiency and quality.
Here is a comprehensive list of how flow meters might be used throughout a beer brewing system:
1. Small, homemade brewing systems
  • Water treatment: Maintaining a proper water ratio is crucial for the flavor and quality of beer in homebrewing. Flow meters help by accurately measuring the water entering the system and ensuring that minerals or additives are mixed in the correct proportions.
  • Mashing: During mashing, water is mixed with crushed grains to convert starches into sugars. A flow meter helps maintain a steady water flow through the grain bed, which is essential for stabilizing the mash temperature. This stability improves sugar extraction efficiency, leading to better fermentation results.
  • Sparging: Sparging involves rinsing the grain bed to extract the remaining sugars. A flow meter controls the rate at which water is added, ensuring the sugars are efficiently washed out without disturbing the grain bed.
  • Boiling: When transferring wort to the boil kettle, it is essential to measure the volume accurately. Flow meters help ensure the right amount of wort is cooked, which is crucial for utilizing hops and achieving the desired beer strength.
  • Chilling: After boiling, the wort needs to be cooled quickly to prevent contamination and prepare for fermentation. Flow meters regulate the flow through a chiller, ensuring the wort reaches the ideal temperature efficiently.
  • Fermentation: Additional ingredients, such as water or flavorings, may be added during fermentation. Flow meters ensure these are introduced at a controlled rate, which is essential for maintaining the desired flavor profile and consistency.
  • Bottling/kegging: Accurate filling is key to minimizing waste and ensuring each bottle or keg has the right amount of beer. Flow meters help achieve this precision, which is especially important for maintaining carbonation levels and preventing spoilage.
2. Large, industrial brewing systems
  • Water supply management: Large breweries use significant amounts of water, and flow meters help track and manage this usage.
  • Mash transfer: In industrial settings, transferring mash between vessels requires careful flow management to optimize sugar extraction. Flow meters prevent issues like channeling, where water takes the path of least resistance, potentially leaving sugars behind.
  • Wort boiling: Recirculating wort helps distribute heat evenly during boiling. Flow meters control this process, preventing issues like caramelization or scorching, which can affect flavor.
  • Cooling systems: Rapid cooling is essential to prevent bacterial growth and prepare the wort for fermentation. Flow meters ensure the cooling process is efficient, maintaining the quality and safety of the beer.
  • Fermentation control: Industrial brewers often add gases like oxygen or nitrogen to aid fermentation. Flow meters ensure these are added precisely, which is crucial for yeast health and beer quality. They also help manage carbonation levels.
  • Cleaning-in-place (CIP) systems: Flow meters ensure cleaning solutions are delivered at the correct rates, effectively cleaning equipment without wasting resources.
  • Filtration and fining: Beer passes through filters or fining agents. Flow meters regulate this process, ensuring clarity without stripping away the desired flavors.
  • Blending: Precise ratios are essential when creating consistent products or new blends. Flow meters ensure different batches are mixed accurately.
  • Packaging lines: Accurate filling of containers is crucial for quality control and legal compliance. Flow meters prevent overfilling or underfilling, ensuring each package meets standards.
  • Waste treatment: Managing wastewater is essential for environmental compliance. Flow meters help monitor and control the flow to treatment facilities, reducing the brewery’s environmental impact.
  • Utility monitoring: Flow meters track utilities like steam and refrigerants, which are essential for various brewing processes. This monitoring helps optimize efficiency and reduce costs.
Essential Requirements for Beer Brewing Flow Meters
Brewers must understand the criteria for flow meters to make informed choices when selecting flow meters for their brewing systems.
  • Food-grade materials: To prevent contamination, components that come into contact with the beer must comply with essential food safety standards, such as those from the European Hygienic Engineering and Design Group (EHEDG) or the Food and Drug Administration (FDA).
  • Durability and resistance: The meter should withstand the changes in temperature and resist corrosion from cleaning agents like steam and alkaline solutions, ensuring long-term reliability. The flow meter must be designed to operate effectively in cold (around 36 F [2 C]) and damp environments typical of brewing settings. Always check manufacturer specifications for details on materials and construction to ensure the flow meter meets the specific demands of the brewing environment.
IMAGE 2: An electromagnetic flow meter measuring the flow rate on a water pipe
Flow Meter Types for Beer Brewing
Surface acoustic wave (SAW) flow meters
SAW flow meters use sensors to detect sound waves in liquids and turn this information into flow rates. SAW flow meters do not touch the liquid directly, lowering the contamination risk and making cleaning easier. This helps maintain cleanliness in breweries. Also, they exert minimal impact on pressure, which helps keep the brewing process smooth.
Electromagnetic flow meters
Electromagnetic flow meters, or mag meters, use electrodes to create a magnetic field; when conductive liquids like wort, beer or water pass through, they generate a voltage corresponding to the flow rate. These meters are ideal for breweries because they have a hygienic design and handle various flow rates and temperatures. With no moving parts, mag meters are highly accurate and require little maintenance. Their design does not obstruct the liquid flow, which helps maintain the quality and consistency of the beer. They also ensure a steady flow without causing pressure drops, which is essential for delicate brewing processes. However, mag meters only work with electrically conductive fluids, so they cannot measure gases or steam, limiting their use to liquid phases in brewing.
Coriolis flow meters
Coriolis flow meters use vibrating tubes, which twist as the liquid flows through. The attached sensors detect the change in vibrations to accurately calculate mass flow and density based on the Coriolis effect. Coriolis flow meters handle various flow rates and remain reliable despite temperature, pressure or viscosity changes. They do not have any moving parts, so they require minimal maintenance, which offers long-term durability. While they can be more costly and complex to install, their accuracy and detailed data make them a worthwhile investment for breweries.
IMAGE 3: Coriolis flow meter
For more on flow meters, visit pumpsandsystems.com/tags/flow-meters.
