Even though most Winter Olympic venues are held in locations that are likely to have white winters, there is no guarantee that Mother Nature will deliver. The host of the Winter Olympics must ensure that plenty of snow is on the ground once the games begin. Sochi, Russia, the site of the 2014 Olympics, was an unlikely choice for the winter games because it sits on the shores of the Black Sea in a tropical climate. However, a short drive north of Sochi is the Caucasus Mountains—an area well-suited for Alpine Ski events. Despite the high probability that natural snow would cover the ground during the games, the Sochi 2014 officials could not take any chances. They began taking bids from firms that produce snow when nature does not provide it. This process began before the 2010 games in Vancouver, Canada. Torrent Engineering of South Bend, Ind., won the contract to design and build the snowmaking system for the Vancouver and Salt Lake City Winter Olympics, and was also selected to develop the systems for Sochi.
Producing Snow
Co-owners of Torrent Engineering, Joe Cousins and Mark Meadows, began the engineering design work in 2008 to ensure that the Rosa Khutor Resort would have enough snow to support the alpine, snowboard, freestyle and cross-country events. A snowmaking machine used at night the during Sochi Olympics. Courtesy of Torrent Engineering
A snowmaking machine used at night the during Sochi Olympics. Courtesy of Torrent Engineering- The requirement to move the water up the mountain from the source—1,000 meters of vertical rise
- Designing a system to provide the amount of snow required
Powering the Pumps
The motors used to power the pumps were supplied by Nidec Motor Corporation, a motor and controls manufacturer headquartered in St. Louis, Mo., that is a longtime supplier to all three firms. The primary pump station, which was responsible for the initial lift from the lake, was outfitted with 14 vertical pumps, each powered by vertical, solid-shaft motors. These 6-foot tall motors are 5,012-frame, 600-horsepower vertical pump motors. The Sochi system had two booster stations that were responsible for pumping the water from the main pump house to the 400 fixed snowmaking guns strategically placed on the mountain. Nidec also provided the smaller fan motors for these units. These booster pumps—five at one location, two in another—were equipped with 5,008-frame, 300-horsepower vertical pump motors. The motors are a vertical design that can be used on normal, medium or high-thrust applications. This application was high-thrust, which occurs when a vertical turbine pump is used. Vertical turbine pumps are typically used for lifting water from wells and up elevations. This type motor is often used for moving water and wastewater in municipal and industrial applications. Other applications for these motors include water movement in the mining industry, for water treatment and dewatering, and for cooling water circulation in power generation. Big vertical motors are also used for flood control and large-scale irrigation systems.
