It is just past 10 on a Friday night when the phones of the on-call collection systems operators start ringing. It is an alarm for another pump clog at a sewage lift station—the second one in a week. If this situation sounds familiar, it might be time to retrofit a two-shafted grinder into some lift stations. Every municipality is a candidate for a grinder retrofit, and every municipality has a problem pump station network. There are several qualifiers that can flag a station as an ideal candidate for a retrofit: an older lift station not designed for higher-solids loading, outdated grinding equipment and, of course, recurring plugs in pumps that require manual cleaning.
Why Retrofit with a Grinder?
Many sewage lift stations in service were not designed to deal with the high-solids content found in today’s sewage. The heavy solids loading, often from disposable wipes, can easily overwhelm traditional pumps, including solids-handling pumps. Typically, when operators find their pumps clogging and failing, wipes-related clogging is the reason. Sewage composition has changed, so the industry standard of the 3-inch spherical solid that pumps were designed to pass no longer meets today’s needs. The addition of a grinder can maximize a pump station’s efficiency while curtailing overtime and unplanned maintenance costs. Grinding wipes and other waste before they reach the pumps is an effective method for preventing damage, eliminating risk, and reduce the time and energy costs associated with clogging. When the wipes are shredded into small enough pieces they do not reweave, rope together or form cumbersome rag balls in the lift stations, they remain in suspension and can be pumped easily.
Location Is Critical
In a perfect world, every grinder could be retrofitted within the influent pipe or channel to the lift station before sewage enters the wet well. In many cases, however, installing a grinder in the inlet is not possible. In an older pump station, it is likely that no accommodations were considered in the design for installing a sewage grinder. In a retrofit scenario, a few things must be worked around inside because the structure of the wet well cannot be changed. While space constraints are one of the major factors in a retrofit, grinders can be worked into nearly every station’s configuration. A common technique when retrofitting a grinder is to mount it to the wall of the lift station’s wet well in front of the influent pipe. The engineering process of mounting should consider space constraints, other equipment (like pumps and float switches in the wet well) and accessibility for easy inspection and service. A perfect station does not exist, either in terms of space or flow rates. In heavy storm flow events, an overflow bar rack, which serves as backup, can be beneficial. Another possible scenario is a lift station wet well that is too small for any additional equipment besides the pumps. In these situations, a simple grinder vault can be added upstream of the wet well in the influent pipe. Often during a retrofit, prior equipment components can be reused.The Ins-and-Outs of a Retrofit
While the actual retrofit should be simple, pay attention to the details of the process. Take good notes. Set clear expectations. Once the grinder is installed, follow the maintenance procedures.
Collections operators should follow along with every step of the retrofit. While planning, it is important to take notes about what flow expectations are being used in sizing the grinder and what type of equipment fits the budget. It is also imperative that operators work with suppliers to set clear expectations so there are not any surprises during the process.
Also, be aware of the maintenance required once the retrofit is complete. While operators will still need to do the typical annual maintenance on the grinder, the maintenance on the pump that the grinder is protecting decreases dramatically with the help of a trusted supplier.
