Rethink instrumentation & improve uptime
04/30/2014
May 22, 2014 1 p.m. Eastern
Free Webinar Click here to register now. Pressure gauges are early warning devices that can identify potential problems before a failure or safety incident occurs. This webinar will help you rethink the role pressure gauges play in improving your plant’s productivity. Expert Jason Deane discusses how pressure gauges support a plant’s reliability-centered maintenance efforts. Learn about the five-step audit process implemented to reset and sustain the accuracy of a plant’s mechanical gauge population. Deane also presents research about the current state of pressure gauges, the trends driving it and the associated risks. The webinar also features the most common reasons for gauge failure identified by WIKA’s Full Audit Service Team after performing more than 300 instrumentation audits in chemical, petrochemical, oil & gas, pulp & paper and power generation plants. This webinar will help you learn to:- Improve uptime
- Lower expenses
- Reduce safety risks
- Eliminate unplanned shutdowns
- Address potential problems before failure
- Support reliability-centered maintenance efforts
- Identify reasons for gauge failure
Speaker
Jason Deane
Senior Instrumentation Engineer
WIKA Instrument, LP
Jason Deane is a senior instrumentation engineer at WIKA Instrument, LP. He serves as a member of the company’s Full Audit Service Team (FAST), a value-added services program that provides gauge expertise to processing plants. As a FAST engineer, Deane investigates, diagnoses and corrects issues with pressure and temperature instrumentation to improve plant safety and operations. Prior to joining WIKA, he worked as a customer reliability engineer and sales engineer for John Crane where he specialized in failure analysis, rotating equipment and engineering design. He holds a degree in industrial & systems engineering from Virginia Polytechnic Institute and State University.
