Thanks to recent technological developments, split mechanical seals are now a viable solution to seal large shafts on rotating equipment.
by John Sousa
September 26, 2016
Large influent pumpImage 1. Large influent pump (Images and graphics courtesy of A.W. Chesterton Company)
Wastewater and water distribution systems move significant volumes of water and wastewater through collection, distribution and treatment facilities to achieve the core function of these operations. As the volume of processed fluids increases, so do the size and complexity of system requirements.
Pumping systems must be designed to handle the normal volume of process flow through the treatment stage as well as the maximum runoff volumes that occur as a result of excessive rain and other factors. These designs also need to take into account equipment reliability and potential downtime.
As pumping systems get larger, sealing system requirements become more complex and difficult to implement.
Many factors affect reliable large pump shaft sealing. Shaft size, pump speed, pressure, water sediment content, startup conditions, cavitation, vibration and other factors will affect the applicability and long-term success of the sealing device.
While legacy main-shaft sealing devices were designed a century ago based on available technology, these seal designs are still the primary seals used today.
When choosing the best sealing solution for their wastewater applications, end users must understand the available technologies and their facilities’ specific needs. Having knowledge to drive the decision will ensure an economical and reliable choice.
Legacy Sealing
Compression packing has been used for more than 100 years. At the turn of the 20th century, it was the best available technology. Most pumping devices were designed to use compression packing to seal the pump shaft and incorporate a stuffing box to contain the multiple rings of packing used to seal the shaft.
When this technology is used, cut packing rings are installed around the shaft and pressed into the stuffing box. A packing gland is tightened, compressing the material axially and radially, while creating a dynamic seal between the pump shaft and the packing.
End users must be careful to avoid overtightening the packing gland, which can cause the packing to overheat as a result of excess friction between the packing material and pump shaft. Flush water lubricates and cools this sealing interface while keeping solid contaminates away from the stuffing box area.
When materials such as wastewater are pumped, solids tend to embed in the softer packing material, accelerating the wear of the pump shaft. A clean and reliable flush source will help enhance and improve the reliability of the packing. Any interruption of clean flush water to the compression packing will cause the packing to overheat, accelerating both packing and shaft wear, increasing seal leakage and necessitating maintenance intervention.
Compression packing is usually the sealing solution that original equipment manufacturers (OEMs) use to seal equipment. It is a versatile option that does not require dismantling the pump or equipment during installation. This is especially important for larger pumps, which require special handling equipment to lift and move. The downtime required to move and restore large pumping equipment is a significant concern. In critical applications, such as influent or effluent pumping where larger pumps are used to move wastewater streams, downtime can be detrimental, especially in the face of uncertain weather conditions and additional flows into the treatment plant.
While compression packing is a flexible sealing device, it requires maintenance for break-in periods and for adjustments to reduce leakage to an acceptable rate. Packing also requires some leakage to operate long-term. This leakage can cause secondary issues such as premature bearing failure and collateral equipment damage that will lead to unscheduled equipment downtime. Wastewater leakage is a biohazard that is a safety issue in any facility.
Packing also wears the dynamic sealing area where it seals against the sleeve or shaft of the pump. These occurrences will affect the run life of the pump and lead to costly downtime for sleeve, bearing and component replacement.
Compression packingFigure 1. Compression packing compresses against the pump sleeve, causing sleeve wear.
Mechanical Seals
Another option for sealing pumps and other types of rotating equipment is axial mechanical seals. Unlike compression packing in which dynamic sealing occurs radially between the packing and the pump shaft or sleeve, a mechanical seal typically seals axially between two seal faces, eliminating much of the shaft wear caused by packing.
Mechanical seals are designed to seal leak-free, enhancing sealing reliability and minimizing pump damage caused by leakage. Eliminating leakage during pump operation will reduce the risk of bearing contamination and premature failure. Collateral equipment damage also can be eliminated, which will further increase sealing reliability and reduce operating costs.
Split mechanical seals, where seal components are radially split, have been commercially viable for more than 30 years and have gained wide acceptance in various process industries. Split mechanical seals established a radical shift in the mindset of process engineers, allowing a pump to be sealed with a mechanical seal while eliminating the protracted process of disassembling the pump.
Pages
