Do not let a catastrophic event be your wake-up call to adopt a proactive strategy.
All too often, we have found the tipping point to predictive maintenance is a costly breakdown of motors, pumps and related systems, or worse, a serious catastrophe that not only damages equipment and cripples your operations, but impacts employee safety as well. According to a recent U.S. Department of Energy study, 55 percent of those responsible for industrial plant maintenance admitted to characterizing their program as “reactive” and 31 percent as “preventive” only. It does not have to be that way.
It is established in the industry that predictive, rather than just reactive or preventive maintenance of existing equipment, will likely save money in the long run and can also help prevent the development of serious hazards leading to a safety problem. Whether an organizatin is a pharmaceutical facility using small 25-horsepower motors or an oil and gas plant operator requiring a 60,000-horsepower synchronous machine, the same precepts apply: “Take care of it now or pay later.”
Predictive and Preventive Maintenance—You Need Both
Predictive and preventive maintenance are different, but both are complementary and one should not be conducted exclusive of the other. They each can help protect equipment and people.
Predictive maintenance is a process that is custom-designed for your specific system, built out of regular observation and recordkeeping to understand trends and uncover anomalies. End users can, therefore, leverage this historical data to take future actions to optimize their operational efficiency.
Preventive maintenance is similar to following the maintenance directions in an auto manual—such as when to change the oil, when to check the belts, when to rotate the tires, etc. Most original equipment manufacturers (OEMs) rigorously test their equipment for a battery of conditions that ensure peak performance in many applications. Following included operating and maintenance documentation is always advisable.
Reaching out to the OEMs of major pump platform components may also be a good idea. In many cases, they will have deep engineering expertise, application performance knowledge and global experience that your team could use.
With larger companies, a good knowledge base often exists in-house on most system components. However, in many of the best organizations, this knowledge is refreshed regularly with instruction by acknowledged industry experts with deep domain expertise. This internal expertise can also be supplemented from time to time with consulting experts in advanced diagnostics and troubleshooting technologies. Diagnostics can make all the difference in the world, and used in a healthy predictive maintenance program, will catch problems before they severely impact operations.
A few OEMs may have deep technical knowledge on multiple components of equipment and could be made available as a consultant on the finer points of condition monitoring instrumentation and diagnostic services for monitoring machinery vibration. Casting a wider net for knowledge of the system components will help develop a firm foundation upon which a truly predictive maintenance program can be built.
Economics and Safety
The primary outcomes of predictive and preventive maintenance can have a real impact to an end user's bottom line. These measures, too, can provide savings based on the avoidance of downtime, damage to equipment and employee wellbeing.
Many risk studies use similar numbers to illustrate the inherent advantage of adopting a more proactive maintenance approach. They can also be used as a template to uncover the resulting costs in operations to craft a more realistic model.
Consider that a reactive maintenance strategy would likely contain up to 14 percent risk, which equates to $140,000 of yearly maintenance on every $1 million worth of existing assets. Compare this to a predictive maintenance strategy, which would contain less than half the risk, about 6 percent, which equates to $60,000 of yearly maintenance per $1 million of existing assets. That is a difference of $80,000 per year. End users may find that these resulting savings will easily pay for a predictive program.
Then consider the other savings not mentione—such as unplanned downtime, injured workers and strained customer relationships. The business reasons that justify this path become more evident as the real costs are investigated.
Through experience, making adjustments now—perhaps investing money now—is better than waiting for a disaster to happen and paying ten-fold from having personnel injuries, line stoppages and equipment replacement.
Some recommendations are given below to make end users' systems as fail-safe as possible. These can make maintenance managers, plant operations personnel, financial personnel and the CEO rest better at night.
Based on sound industry practices and experience, a comprehensive proactive maintenance strategy requires a system that captures repetitive failures so that appropriate corrective changes are made. This demands good record keeping of all maintenance programs and a root-cause-analysis of any maintenance performed. These records should be reviewed annually and semi-annually.
Conduct both preventive and predictive maintenance on systems. Follow the manufacturer's minimum maintenance recommendations. Regularly take non-intrusive measurements—such as vibration analysis, infrared (IR) analysis and insulation readings—and then compare these measurements so that equipment failure can be predicted. Making these predictions allows maintenance and production departments to work together to schedule repairs.
In today's facilities, power quality problems can wreak havoc on high-tech controls and electrical devices—such as transformers, switchgear, switchboards, power panels, motor control centers and variable frequency drive systems. A recent study found that up to 80 percent of these power quality issues are born in facility electrical distribution and grounding systems. Consider using a power system study to maintain (and upgrade if necessary) the power-delivery infrastructure.
Apply vibration diagnostics to detect mechanical and electrical anomalies in motors and the rotating equipment that they drive. Problems can involve misalignment, improper mounting, infrastructure contamination, bent shafts, a faulty motor or an unbalanced motor or pump.
Apply IR analysis to detect electrical system overloading, under-loading or faults with connection. It also detects mechanical abnormalities, such as temperature differentials in the bearings or couplings. Detecting temperature differences or elevated temperatures along pump seals or gaskets can indicate impending failures.
Motor insulation testing—or static testing—verifies typical motor faults. Insulation testing helps verify if there are high-resistance connections within the motor winding, ground wall insulation condition and turn-to-turn insulation. Anomalies discovered in test results can lead to catastrophic failure if not corrected.
Bearing troubles are often a leading causes of motor failure. Contamination and poor lubrication are leading causes. Excessive loading or preassembly damage (from misalignment, pump cavitation, excessive pump flow and exposure to temperatures outside bearing thermal limits) can result in failures as well. Misalignment occurs when coupling the motor shaft to the pump shaft. In such cases, dynamic testing is required, and the equipment is activated until the operating temperature is reached, and then the equipment is shut down. Alignment is performed while the motor and pump are at, or close to, operating temperatures.
If a motor fails, the maintenance manager must decide if the motor should be replaced or rewound. Waiting for a motor failure is not the best maintenance strategy. Every facility should have a repair/replace policy. Possible, a rewound motor can work fine and, perhaps, provide even more horsepower than the original. The key bywords are reliability and efficiency.
Some motors will not be put into service for months and instead are stored. The storage location must be clean and dry. Storage temperatures must be between 50 and 120 degrees F. Relative humidity must not exceed 60 percent. Motors with anti-friction bearings must be lubricated.
The goal is to take care of problems before they occur. In the process, end users can ensure the operational efficiency and reliability of their equipment and the safety of their employees.
Pumps & Systems, November 2011
