Misalignment is a frequent cause of rolling bearing failure. It can cause cage fracture, which will result in seizure of the bearing, pump failure and costly downtime. It can also cause edge loading, which will result in early bearing failure. Typical bearing-life calculation tools assume that the bearing’s inner and outer rings are well aligned. A general acceptable alignment is better than 0.003 radian (10 arcminutes) for ball bearings and 0.0012 radian (4 arcminutes) for cylindrical roller bearings. Rolling bearings are manufactured with great accuracy. Great care must be taken with machining practices and assembly accuracies of the mating shaft and housing to maintain this accuracy. In practice, however, the machining accuracy of parts surrounding the bearing must be considered. Sources of misalignment include:
- Nonconcentric housing bores
 - Non-perpendicular shoulders on mating components
 - Bent shafting
 - Errors during installation
 - Baseplate irregularities
 - Non-flat mounting surface
 - Insufficient rigidity of the mounting surface
Diagnose Misalignment
Misalignment in a failed bearing can typically be diagnosed by examining the rolling element path inside the bearing. As bearings rotate, the rolling elements generate a wear path on the inner and outer raceways. A well-aligned bearing will exhibit a running path down the center of the inner and outer rings, while a misaligned bearing will exhibit uneven running paths (see Figure 1).
Figure 1. Typical running paths of deep groove ball bearingsAvoid Misalignment
Misalignment can be avoided by being attentive during the bearing installation process. The first step is the proper design and machining of the mating housing and shaft components. Housings should be rigid to provide firm bearing support. In cases in which two bearings are mounted in one housing, the fitting surfaces of the housing bore should be designed so both bearing seats may be finished together with one operation, such as in-line boring. The recommended accuracy and surface finish of shafts and housings are listed in Table 1 for normal operating conditions (IT values are International Tolerances Grades as per the International Organization for Standardization 286). The shoulders of the shaft or housing that contact the face of a bearing must be orthogonal to the shaft center line.
Mitigate the Effects on Bearing Life
Several bearing solutions are available to help mitigate the effects of misalignment. For example, nylon cages are more flexible than steel cages and can accommodate misalignment better than steel cages. Increasing the internal clearance of the bearing will increase its misalignment capacity. Self-aligning ball bearings can also be used. These bearings have a spherical raceway with a center of curvature that coincides with that of a bearing. This allows the axis of the inner ring, balls and cage to deflect to some extent around the bearing center. However, this design can create a smaller contact angle between the ball and the raceway, which results in a lower load capacity compared to a similar sized, deep-groove ball bearing. The permissible static misalignment in this bearing type is approximately 0.07 to 0.12 radian (4 to 7 degrees) under normal loads. Depending on the surrounding structure, this angle may not always be possible. Because standard L10 calculations assume that the bearing is well-aligned, additional calculations must be made to determine the effect of misalignment on the bearing’s fatigue life. The maximum allowable misalignment of a bearing varies depending on the size and type of bearing, internal clearance during operation, and the load. Assume the fatigue life without misalignment as Lθ 0, and the fatigue life with misalignment as Lθ. The effect of the misalignment on the fatigue life can be found by calculating Lθ/Lθ=0. Figures 2 and 3 show the effect of misalignment on the life ratio for a deep groove ball and roller bearing, respectively. In these figures, the horizontal axis shows the misalignment of inner/outer rings (rad), while the vertical axis shows the fatigue life ratio Lθ/Lθ=0. As an example of ordinary running conditions, the radial load Fr (N) {kgf} for both figures was assumed to be approximately 10 percent of the dynamic load rating Cr (N) {kgf}, and the shaft fit was machined to the recommended value. The decrease of the internal clearance because of the expansion of the inner ring was also considered. Figure 2 was generated using the normal radial clearance for the deep groove ball bearing. The three separate plots represent maximum, minimum and mean effective clearance. The reduction of the fatigue life is limited to 5 to 10 percent up to 0.004 radian of misalignment, therefore, not significantly reducing the bearing life. However, when the misalignment exceeds this limit, life is reduced considerably. In this scenario, an increase of 11μm in internal clearance results in ~0.0015 radian increase in misalignment capacity.
Figure 2. Life ratio for 6200 deep-groove ball bearing
Figure 3. Life ratio for NU315 cylindrical roller bearing
