Q. What sealing issues should a pump user be aware of when dealing with viscous fluids? A. Sealing issues related to viscous liquids are complex. Mechanical seals or sealing devices must be capable of sealing a pump against a range of anticipated viscous conditions, including transient or upset conditions. Mechanical seal components may not perform as anticipated or could be exposed to loads higher than water. Connected with mechanical seals are seal flushing arrangements and associated piping. In many cases, auxiliary systems include secondary components, such as orifices and filters, which may plug or cease to function correctly when handling viscous liquids. The piping is normally external to the pump case and may require heat tracing or other considerations to ensure proper seal flushing. Seal manufacturers should always be consulted for detailed information and for proper selection purposes. To learn more about the connection between viscous liquids and rotodynamic pumps, refer to Mechanical Seals for Pumps – A Cost-Saving Guide to Proper Selection, Installation & Operation, as well as ANSI/HI 9.6.7 Rotodynamic Pumps – Guideline for Effects of Liquid Viscosity on Performance.
 Figure 1. Newtonian fluid example.  Figure 2. Dilatant fluid example.  Figure 3. Plastic fluid example.  Figure 4. Pseudo-plastic fluid example.  Figure 5. Thixotropic fluid example.  Figure 6. Rheopectic fluid example. (Graphics courtesy of Hydraulic Institute)
