Metallics and plastics offer advantages for different applications.
by Ken Comerford (Vanton Pump and Equipment Corp.)
March 17, 2015
Choosing the right pump material to handle aggressive fluids is critical to the success of any processing operation. Aggressive fluids are those that either corrode or abrade the pumps used to handle them, including acids, caustics, reagent grade chemicals and unknown wastewater effluents. Selecting the appropriate material for handling these aggressive liquids requires careful analysis to avoid incurring the cost of premature pump replacement and downtime.
Metal and plastic are the two major types of materials used for pumping harsh liquids. Pump users must consider multiple factors to select the optimal material for their specific requirements.
Metallics
Historically, exotic metal alloy pumps were the tried and true solution for the proper handling of harsh fluids. These materials were so ubiquitous among processing professionals that corrosion-related pump failure was considered both predictable and anticipated by independent sources. Examples of such sources are Compass and Schweitzer, compendia that detail the expected service life of materials in a given corrosive fluid. The shortcoming of these measurements, however, is that they are taken in a static condition. When these materials must perform at high speeds, their life expectancy is curtailed even further.
When dealing with metals, users must be aware of the four types of metallic corrosion.
  1. General Corrosion - The formation of a passive film on a metal's surface is what prevents it from degrading.
  2. Galvanic Corrosion - This phenomenon occurs when two or more disparate metals come in contact with one another or when metals with the same analysis have different surface conditions and an electrolyte is present, which forms an electrolytic cell.
  3. Stress Corrosion Cracking - Since all metals have residual or applied stress, they are prone to stress corrosion cracking, which is affected by extreme thermal changes, excessive vibrations, and expansion or contraction.
  4. Intergranular Corrosion - This type occurs only at the grain boundaries of carbon-containing austenitic stainless steels. If the steel is heated above 1,000 F, the carbon is released at the grain boundaries, causing the area to become more susceptible to corrosive attack.
While the shortened service life of a metallic pump caused by corrosion is problematic, corrosion may also contaminate the pumped liquid and compromise the fluid's composition. A properly selected plastic material, however, would be inert to the most harsh or caustic fluids because plastics are compatible with such liquids and would not react on contact. The correct plastic for a particular application will solve most fluid transfer, dosing and collection problems.
Plastics
How does a user select the right plastic for handling a specific harsh liquid? The first step is to recognize that choosing the ideal plastic pump is not a cure-all for every pumping application. In high-temperature or high-pressure applications, metallic pumps perform better (see Table 1). In applications in which chemical compatibility is a primary consideration, however, plastics are considered the material of choice.
Table 1. A comparison of the performance of different materials of construction Table 1. A comparison of the performance of different materials of construction
The two major non-metallic groupings are thermosets and thermoplastics.
Thermosets
Thermosetting plastics are composites, not homogeneous materials. Commonly referred to as fiber reinforced plastics (FRP) or glass reinforced plastics (GRP) materials, thermosets are constructed of vinyl ester or epoxy resin reinforced by glass fibers.
The strength of FRP and GRP materials is influenced by variations in its composition.For this reason FRP/GRP pumps are commonly referred to by their trade names, which provide specific analyses of the materials made by their manufacturer. FRP/GRP's rigid properties (their tensile strength, for example) more closely match those of metallics than thermoplastics. Their resistance to corrosives increases as vinyl is added to their formulation, while their resistance to solvents is enhanced by their epoxy content.
Thermosets can be custom-formulated to meet specific service conditions, because different formulations of their components (glass fiber/epoxy) can impart different values to the composite material. For this reason, standard corrosion charts are not always helpful. Instead, performance characteristics should be determined by the manufacturer's and the user's prior experience. Because of the specificity of this type of material, users should employ careful consideration when selecting thermoset pumps for applications in which the fluid is unknown. Thermoset pumps will resist most chemicals and can reliably be used in applications in which the fluid reaches 300 F or higher.
Users should be cautious, however, when using thermoset pumps to handle solids-containing liquids. In these applications, the pump's resin surface may be abraded, exposing the reinforcing fibers. This may expose glass fibers beneath the surface, which could result in severe damage and even pump failure. Since FRP/GRP pumps are formulated to handle a narrow and specific type of caustic liquid, they are limited in the range of harsh liquids they can handle effectively.
Pages
