Because well pressure declines and flow rate changes throughout the well lifetime, pumps must be versatile.
by Asser Amin & Mohamed Hazem
December 3, 2015
Oil and gas production wells initially have sufficient pressure for gas and condensate to flow freely from the wellheads through export pipelines to the nearby existing gas plant under reservoir pressure. As the reservoir pressure declines, the peak gas will no longer be attainable. As a result, pumping equipment is needed to assist the recovery as the reservoir production rate and pressure decline.
In one case study, the export condensate pump must cover operating conditions related to production rates and pressure deterioration without pump re-bundling or piping modification. The pumps need to handle condensate at various operating conditions. Because of gas well decay, condensate is pumped as a fluid near its vapor pressure and is subject to flash easily with slight pressure or temperature changes.
The pressure deterioration in the well leads to an increase in the pump head from 940 to 1,800 meters. Eventually the gas condensate mixture becomes lean (less condensate), and the condensate flow rate falls from 71 cubic meters per hour (m3/hr) to 27.6 m3/hr.
An illustration showing the efficiency loss at low flow ratesFigure 1. An illustration showing the efficiency loss at low flow rates (Images and graphics courtesy of Enppi)
Pump Selection
The user selected barrel-type condensate pumps that were compliant with American Petroleum Institute (API) 610 BB5. The double casing radially split multistage horizontal pumps have 16 stages in a back-to-back (B2B) configuration.
Centrifugal pumps convert only a portion of the power input by the driver into hydraulic energy. The remaining energy is mainly converted into heat. These internal losses in energy depend on the flow rate and eventually get dissipated through the pumped liquid. In most pump curves, the lower the flow rate, the lower the pumping efficiency and consequently the higher internal losses.
Having low flow concerns will lead to constraints against low flow rates in high pressure, high power pumps. Temperatures will rise significantly because of the ratio between the power input and the mass flow of the pumped fluid. The temperatures should then be investigated to ensure that no internal flashing occurs because of this temperature rise. Users should also check internal areas such as bushings and wear rings for a rise in temperature.
Pump Minimum Continuous Flow
The pump industry uses two terms to define the minimum possible flow rate for safe pumping operation. Minimum continuous stable flow (MCSF) is mainly related to pumped fluid recirculation that may result in cavitation and vibration. Minimum continuous thermal flow (MCTF) is concerned with temperature rise at lower flow rates. The minimum operating flow is the higher of the MCTF and MCSF.
Figure 1 shows the relationship between the flow rate, pump efficiency and power absorbed. As the curve approaches lower flow rates, the efficiency drops and the internal losses increase dramatically. This behavior adds heat to the pumped fluid at these low flow rates. This heat addition should be calculated to obtain the required MCTF.
Generally, MCSF prevails in most applications with much higher rates than MCTF and becomes the defining variable. In this case, however, MCTF dominated because of the following:
  • Low specific heat (Cp) value. The condensate Cp is almost half of the Cp of water, so the same energy that would raise water's temperature by one degree Celsius will heat up condensate by two degrees Celsius.
  • High-pressure, low-flow operation.
  • The pump suction pressure was slightly above vapor pressure, which means that any loss in pressure or increase in temperature caused the pumped fluid to turn to vapor.
MCTF is a concern for the selected high head multi-stage BB5 export pumps. In this case, liquid condensate heats up as it passes through the pump stages and internal parts. The temperature rise is likely to occur in the following cases:
  • through the pump's 16 stages where pressure develops.
  • because of the throttling of the condensate in the clearance of the thrust balancing device.
The balancing line then acts as a passage between the axial thrust balance device and the suction side of the pump. If heated to a certain limit, the liquid condensate may flash and lead to catastrophic pump damage. This concern leads to operating constraints in light hydrocarbon applications, where the pump intake suction is directly fed from an elevated condensate separator.
Thrust Balancing Systems
Thrust balancing is a necessary part in every centrifugal pump arrangement. Thrust forces are magnified in high pressure, multi-stage pumps to a level that should be eliminated or at least reduced. Net thrust values could be enhanced by:
  • the B2B arrangement provided to the impellers of the pumps.
  • a thrust-balancing device with a leak-off line to eliminate the residual thrust forces in the pump. This will increase the rotor dynamic stability and improve axial thrust compensation.
Pump arrangement installed at site showing the return line location to the first stageImage 1. Pump arrangement installed at site showing the return line location to the first stage
The balancing thrust bushing is found after the eighth B2B stage. A line is routed from the bushing's other side back to the suction. The size of the bushing must allow as much net thrust as residual thrust forces. Note that the area multiplied by the pressure difference between the suction and eighth stage discharge equals residual force.
Pages
