IMAGE 1: A tanker train (Image courtesy of ABB)
Enhancing efficiency, automation and reliability.
ABB
The midstream oil and gas sector relies heavily on efficient, reliable pump operation to manage the movement, storage and processing of liquids—including crude oil, refined products and produced water. As operational demands increase and environmental pressures intensify, midstream operators seek smarter automation and improved energy efficiency without compromising system stability or safety. Variable speed drives (VSDs) or variable frequency drives (VFDs) can enable precise control of pumps, improve mean time between failure (MTBF), reduce wear and tear, enhance process control and lower energy consumption.
Although VFDs have been utilized for many years, it is imperative to select the correct VFD whose feature set aligns specifically with the needs of midstream pumping applications. Today, specialized VFDs are manufactured with advanced pumping features that align well with midstream pumping needs. These VFDs include built‑in application logic that eliminates the need for external programmable logic controllers (PLCs) in many scenarios, significantly reducing engineering time and operating costs.
Cavitation Detection & Dry Pump Features
In midstream oil and gas operations, emptying tanks, railcars and transport vessels is a daily necessity. One application where this process would be leveraged is by a user who pumps hydrocarbons (e.g., crude oil, ethanol, corn oil or a multitude of products) at ambient temperature, with specific gravities ranging from 0.8-1.0 and materials from bulk tank cars utilizing an American National Standards Institute (ANSI) pump with an induction motor at 3,560 rotations per minute (rpm). Operators must ensure all usable liquid has been removed, pumps do not run dry, cavitation is minimized, pumping equipment is protected and safety and environmental regulations are met.
Traditionally, this process requires hands-on operator supervision, as pumps are started manually, monitored by ear and vibration and stopped once flow appears to taper off. Manual pump control can raise cost, increase pump wear and introduce inconsistency and risk.
The goal of tank emptying applications is to extract the final portion of usable product from the tank in the most efficient way possible. Utilizing an intelligent VFD allows for automation of the extraction of the final portion of liquid after full speed pumping becomes ineffective.
Intelligent Pump Control Features
Historically, protecting pumps from cavitation demanded extensive drive programming and added instrumentation to detect when net positive suction head available (NPSHa) approached or fell below net positive suction head required (NPSHr). Today, pump-centric VFD algorithms—particularly sensorless cavitation prevention logic—offer terminal operators a more reliable and economical solution that also reduces offload times. Cavitation is identified in real time by monitoring motor torque, speed fluctuations and, when available, pressure feedback.
Once the VFD detects the characteristic shift in hydraulic behavior, it automatically takes corrective action without shutting down the pump. Although counterintuitive, the corrective response involves slowing the pump, which restores stable liquid flow and prevents the pump from ingesting vapor or air.
As this controlled slow-down is executed to prevent cavitation, the pump continues to pull residual liquid at a lower flow rate—effectively “sipping” the remaining fluid from the bottom of the vessel. This empties tanks more completely, extends pump lifespan and lowers energy consumption during the final stage of evacuation.
Safe Shutdown Before Damage
After low‑speed sipping, true dry‑run conditions are inevitable. Drives with this feature identify dry running through characteristic changes in torque, power and flow indicators, then enter a dry‑pump protection mode to shut down the pump before mechanical damage occurs.
Key Benefits
There are many benefits to using VFDs in midstream operation, including:
  • Fully automated pump‑out operation (start full‑speed pumping cavitation detection slow sipping dry‑pump protection shutdown)
  • More complete tank and railcar emptying, improving product recovery and reducing waste
  • Minimized cavitation risks and prevention of dry running (reduced impeller pitting, seal failures and bearing wear)
  • Reduced operator intervention, freeing personnel for higher‑value tasks
  • Less external control hardware required, as the drive’s firmware handles detection, control and shutdown
  • Increased MTBF due to longer service intervals, decreasing operational costs
Moving Water Long Distances Using Intelligent Flow & Pressure Control
Water management in midstream oil and gas involves substantial fluid transfer operations, including moving produced water from well pads to central handling facilities, transferring treated water to disposal wells, pumping water from storage ponds to hydraulic fracturing locations and transporting water through discharge pipe or temporary lay‑flat hose.
This segment is among the most energy‑intensive in midstream operations. Key difficulties include maintaining stable pressure over long distances, handling elevation changes, preventing leaks and avoiding water hammer.
Efficient Long‑Distance Water Transfer With Intelligent Drives
Built‑in flow calculation and control
Intelligent VFDs can calculate flow without a dedicated flow meter by leveraging motor torque, speed and pump performance models. This enables maintenance of target flow rates, horsepower optimization, anomalous flow detection (e.g., leaks) and automatic balancing in multipump systems.
Pressure control for safe and stable water transfer
Consistent pressure is essential for long‑distance water transfer. These VFDs employ closed‑loop proportional/integral/derivative (PID) control, adaptive ramping, soft‑start/soft‑stop and rate‑of‑change limits to maintain stability and avoid surges. This prevents hose rupture, ensures stable flow from booster pumps, reduces water hammer and protects pump components from pressure spikes.
Multipump coordination and booster station control
Water transfer often relies on multiple pumps in parallel. The VFD supports pump alternation, lead/lag staging, PID sharing and load equalization, enabling coordinated operation without a central PLC. Booster stations utilizing intelligent VFDs can synchronize pressure and speed, sharing load to maximize efficiency and availability.
Handling elevation changes
Elevation variations influence total dynamic head (TDH). The VFD can automatically adjust speed based on real‑time pressure and flow demand, utilizing either sensorless flow control or the onboard PID loop to maintain setpoints as the pipeline follows terrain, increasing pressure on climbs and reducing power on descents to avoid overpressurization.
Energy Efficiency
Pumps account for a large share of total energy use in water transfer. The VFD can improve efficiency by matching speed
to demand, minimizing throttling losses and leveraging energy optimization features. Compatibility with high‑efficiency motors can further reduce operating expenses (OPEX) and emissions, benefiting both generator‑powered and grid‑
connected sites.
Why This Matters for Midstream Operators
  • Water transfer is a major operational expense; pumping efficiency materially reduces OPEX.
  • Precise pressure control helps prevent leaks and environmental incidents in temporary hose networks.
  • Drive‑based automation eliminates manual valve throttling and frequent setpoint adjustments across booster stations.
  • Smoother operation with fewer surges extends the life of pumps, seals, hoses and valves.
  • Total system cost is lowered due to a reduced need for flow meters, PLCs and external PID controllers.
Intelligent VFDs offer many benefits for modern midstream oil and gas operations, enhancing automation, reliability, environmental compliance and operational efficiency.
