It’s quiet at the Mahanoy City Wastewater Treatment Plant in Pennsylvania. Unless you’d been told otherwise, you wouldn’t know that a 36-inch diameter pump operates night and day in a giant concreted basin nearby. Even when one of the two 84-inch screw pumps is being put through its paces, this plant is still a good neighbor. The Mahanoy City WWTP has not always run so smoothly. The original 36-inch diameter raw sewage enclosed screw pump, which had become increasing unreliable, failed twice, ultimately giving the plant operators no option but to look for a more sturdy and efficient alternative. A heavy-duty enclosed Type C screw pump was chosen. The design has two convoluted flights that are welded to the rotating outer tube, with the lower bearing mounted above water level. “With this new enclosed Type C screw pump we immediately benefitted from an intelligently designed and very well engineered product,” Mahanoy WWTP’s Assistant Chief Operator Josh Ball said.
Catastrophic Failure
Two years later, though, one of the original 84-inch enclosed internal-lift type screw pumps suffered a catastrophic failure, forcing the operators to introduce a temporary (three-month) bypass system. “At the time, this was pretty nerve-wracking,” Ball said. “The bolts on the stainless steel ring, on which the vast majority of the weight rests, simultaneously broke, causing the structure to break in half. It was scary.” For storm events, the town must have sufficient back up capacity, so the decision was made to replace both of the larger pumps. Mahanoy City had little hesitation in deciding to replace the old units with two new 84-inch enclosed Type C screw pumps to match the 36-inch pump that had been working without any issues for the past 24 months..jpg) Image 1. The 36-inch enclosed screw pump (left) is the daily workhorse, and the twin 84-inch screw pumps alternate storm duty. (Courtesy of Lakeside Equipment Corporation)
