Engineered composites have become a solution for longer pump life.
With the market demanding cheaper prices, most pump manufactures have gone outside the U.S. for the casting of metallic parts. Unfortunately, the net effect for the pump owner or end user is a shorter pump life. Metallic parts cast overseas corrode faster and are more subject to cavitation damage. The net effect is that the life of some parts—such as impellers, rings, sleeves and casings have—been shortened.
| A metallic impeller corroded and cavitated even through coating. | A metallic impeller corroded and cavitated. | A bad casting in Stainless Steel with pitting and pockets eroded out. |
A molded non-structural | A machined structural engineered |
Engineered Composite Advantages
Corrosion resistance. One of the most imperative advantages of composites when compared to metal is its ability to resist both corrosion and erosion in saltwater. Composites never corrode in saltwater.
These two impellers ran for three years in salt water–the composite impeller looks like new.
Most composites are also excellent in most chemical applications and are not subject to damage by gasoline, oil or refinery byproducts. Because of these outstanding characteristics, composites prove to be a worthwhile investment in the long run with the reduction of the costs of replacing these parts.
Cavitation resistance. Cavitation damage results when the liquid pressure of the liquid being pumped falls below the vapor pressure of the liquid resulting in the formation of vapor bubbles. These imploding bubbles cause severe damage to all parts resulting in holes in the impeller and casing volute.
The same impeller in structural engineered composite after over two (2) years of operation. It looks brand new.
| A metallic impeller, after only 3 months of operation is salt water. This impeller was subjected to corrosion and cavitation attack. |
| The same impeller in structural engineered composite is non-conductive and, therefore, will not be affected by the effects of electrolysis. | A bronze impeller suffering from the effects of electrolysis after only 9 months of operation. |
Electrolysis and galvanic corrosion resistance. The graphite used in this structural engineered composite is non-conductive, which means that it will not support electrolysis or galvanic corrosion. It also means that the more composite used in the pump, the longer the pump will last. When applied in a corrosive environment, all metallic parts, or components will conduct electrolysis. However, composite materials do not. This enables the metallic pump to last significantly longer, because of the prevention of electrolysis and “pump wash out.”
Galvanic corrosion is corrosion that forms as a result of electrolysis, due to the difference in nobility between two dissimilar metals. Consequently, a reduction in electrolysis leads to an automatic reduction in galvanic corrosion.
Light weight. Composites are significantly lighter than metallic materials. Most composites weigh only 1/6 to 1/5 the weight of their metallic counterparts. The lighter mass means a substantial reduction in the start-up load, shaft movement and shaft deflection, resulting in longer life for the bearings, mechanical seals, casing and wear rings and sleeves. The light weight of the composite products proves to be an excellent investment.
Mechanical and hydraulic balance. Machined structural engineered composite impellers are perfectly balanced and maintain this perfect balance throughout the lifetime of the pump. This is due to precision machining from a solid block of the composite material. In regards to mechanical balance, the center of axis of rotation is in the center of the impeller, which creates perfect symmetry.
Composite impellers, rings and guide bearings will not corrode in saltwater and therefore will not reach an imbalance. In regards to hydraulic balance, all vanes are within 0.002 inches of each other, and all the exit ports are equally spaced with no casting imperfections. When tested alongside cast iron, bronze and stainless steel, composites were the only product that maintained both mechanical and hydraulic balance after six months of saltwater service.
Energy efficiency. With the increasing interest for companies to increase their “green” capabilities, machined composites offer unique possibilities. An existing pump can be made more efficient by redesigning the impeller to make the operating point in the plant, or system, the best efficiency point (BEP).
This bronze impeller from a cooling tower pump is completely cavitated after only one year in service. | The same impeller in structural graphite composite after one year of service shows absolutely no wear or damage. |
Many composite pump companies offer dedicated engineering specialists who focus on improving and increasing efficiency and redesign of impellers to operate at the operating point in the system, which allows for the BEP to be the true operating point in each plant or ship system. The efficiency of the pump substantially improved, and the reliability of the pump is increased.
Life cycle. When the total operating years of composite pumps are examined, it becomes clear that composite materials are an excellent financial and operational solution. Most composite pumps and pump parts operate at least three to five times longer than their metallic counterparts. When the total cost of operation including down time, overhaul expenses, and reliability is reviewed, it becomes clear that composites will save the end user thousands of dollars in energy, operational, replacement and repair costs.
| A main circulating impeller for a two stage intake pump at a power company in NYC after 18 years of service. | A new structural engineered composite impeller for the same 2 stage main circulating pump.
Improved efficiency. Because machined structural composites can be designed using state-of-the-art computerized fluid dynamics (CFD) techniques, structural composite pumps and pump parts (impellers) can be designed to maximize efficiency in a customer's system. For example, if a customer has a problem in which his motor is tripping the system, the impeller can be re-engineered and designed to operate at a higher efficiency without changing the entire pump and/or system. Composite Impeller Surpasses Bronze Impeller EfficiencyUpon the request to redesign an impeller for a German based Pump Company, a structural engineered composite pump manufacturer took on the task to make modifications to improve the performance of the impeller. The composite impeller (left) exhibited an increase in efficiency of 87.8 percent compared to the bronze impeller's 83 percent.
Do your pumps look like this?
If so, consider upgrading to structural composite pumps and pump parts. |
