by Dr. Lev Nelik, P.E., APICS
December 17, 2011
Pumps & Systems, November 2007
Our repair shop came upon a customer that purposely buys oversized pumps and immediately operates them at nearly 80 percent closed valve. Each year, after the hot days of summer simmer down, they evaluate the pumps' performance by measuring flow. If the flow dropped by more than ~10 percent, they slightly open the valve (say 70 percent closed) to compensate and run the pump at this new valve position the next season.
They felt proud of this "pro-active" maintenance program. They pumped mostly clean water, did not worry much about spills and catastrophic failures, and periodically changed packings. Despite vibration levels being around ~0.7-in/sec (pumps were held to the sole plates by only half the number of bolts required, and some sole plates did not even have holes drilled), they did not feel they had any problems.
Each year, several pumps would reach the point where a valve could not open any further. These units were sent to be overhauled. Once the pump returned from the repair shop, the valve was again set almost closed and the story was repeated.
In this profitable privately-owned company, the same mechanics that took care of the pumps also paved the driveways, fixed roofs, and worked on employee cars in their shop. The pumps were rather noisy, but were installed inside the buildings where anyone rarely went (other than to periodically open the valves a bit more). This noise didn't bother anyone, but for those who did complain, the advice was not to listen, or to use plugs.
Another pump repair shop that serviced these folks was regarded as friendly, reasonable and always willing to pick up a worn out pump at the end of each season on time. The only reason we got involved was by accident. At first, it was rather difficult to discuss the concept of BEP, MCSF, vibration criteria, and the need to actually bolt the pumps down so they didn't just sit there like rocket launches held mostly by the flange connection. We talked about the dangers of running pumps significantly to the left of the BEP, which brought us to the question: "What is MCSF"?
Minimum Continuous Stable Flow (MCSF) is defined as the minimum flow below which the pump should not be operated continuously. It can operate there for a short time (such as start-up), but not too long. The main reasons to avoid minimum flow are unstable operation, high radial and axial thrust, vibrations and noise - all of which ultimately deflect the shaft; damage the seal, bearings, and couplings; and reduce reliability significantly. The value MCSF is established by the pump manufacturer and guided by several factors, including pump type, pump energy level, pump Ns and Nss and onset of recirculation, guiding specifications, and experience.
For critical, more sophisticated designs, on-set of suction recirculation often is a main factor.1 For simpler cases, field feedback and experience present opportunities for simplified methods.2 To further clarify things, some specifications simply state the allowable minimum flow (as well as maximum flow, on the other side of the BEP). For example, API-610 spec requires no less than 60 percent as allowable, and no less than 70 percent as preferred.3
Regardless of which method is used, the main objective is to prevent the pump shaft from deflecting excessively and causing seals to leak, bearings to overload, and the coupling to overstress. It is intuitively (I must be careful here!) known that shorter and thicker shafts resist deflecting force better, thus such shaft designs are preferred. The measure of shaft "robustness" (its resistance to deflection, stiffness) is a so-called ratio, L3/D4.
This ratio comes from the deflection formula: y = WL3 / 3EI, or deflection at the end of a cantilevered shaft. Since the moment of inertia for a round bar is I = π x d4 / 64, then substituting we get: y = (64W / 3Eπ) x L3/D4 = k x L3/D4. Thus, for the same load, the lower the quantity (L3/D4), the lower the deflection. Short, beefy shafts have lower L3/D4, which is a good thing.
Consider a typical end suction ANSI design below (see Figure 1), a 1.5 x 1-6. The shaft diameter under the sleeve is 1.125-in, and the length of the shaft from the bearing to impeller centerline is approximately 7-in, thus L3/D4 = 73/1.1254 = 214. Typically, end suction pumps have this "slenderness ratio" between 10 to 300, the lower the better. One of the reasons the design in Figure 1 has high value (214) is because it allows for a double mechanical seal, which requires extra room to fit. Had the design been intended for a single seal only, the shaft could have been shortened, to lower the ratio, but then seal options would be limited.
Minimum Flow Figure 1. A typical end suction pump design; the shaft is relatively slender, with a high value of LS/D4Figure 1. A typical end suction pump design: the shaft is relatively slender, with a high value of L3/D4
Pages
