by Fluid Sealing Association
December 17, 2011
Today, there are ever increasing economic and environmental needs to minimize industrial leakage and emissions. Continued developments in valve packing design and materials have greatly improved the abilities of compression packings to provide reliable sealing performance for years in a wide range of applications and valve types. Proper installation and maintenance are essential to achieve optimum performance from these packings. Since the majority of the current emissions come from valves, an understanding of the importance that proper valve packing gland loading has on meeting these needs is essential.
Often perceived as simply "tightening" the gland to achieve an initial seal, improper torque methods will result in reduced packing life, increased valve maintenance, leakage and potential system issues when the valve cannot be actuated.
Applying Sealing Force
Torque, applied to the gland bolt nuts during valve packing installations and readjustment, creates an axial force on the packing gland. This axial force transfers to the packing, causing it to compress axially and expand radially with a resultant force that achieves a seal against the static stuffing box bore and the moveable stem. It also provides the packing materials with the resistance needed to contain the system pressure (see Figure 1).
This radial force of the packing against the stem is a major factor in the amount of friction that the valve stem must overcome when actuated. This is an extremely important factor in mechanically operated valves. When torqued properly, the packing set can create a tight seal with the least amount of friction.
The gland nuts should not be over-torqued or under-torqued. When over-torqued, the resultant stem friction can be high enough to prevent the valve from operating properly, resulting in reduced plant efficiencies and safety. Over-torqueing results in increased packing consolidation, which reduces gland adjustment travel and shortens the service life of the packing. The potential for packing material degradation and extrusion also increases when excess torque is applied. Under-torqueing may result in immediate leakage and possible loss of the packing due to under consolidation. Packing material blow out is possible under this condition. It is important, particularly with the number of packing manufacturers and packings available, to fully follow the manufacturer's instructions for proper torque requirements and gland loading.
For the radial force to be evenly distributed through the packing, the axial force must be applied evenly from the gland nuts. Use of a packing gland with a beveled nose will result in uneven application of torque. Uneven radial loading may result in development of a leak path(s) within the valve.
Even when properly torqued, the ability of the packing to maintain an effective seal over its life can be adversely affected by service conditions that compromise the gland loading. In conditions where temperature cycles cause the expansion and contraction of the dissimilar materials comprising the sealing system, gland re-torques become common. Engineered disc springs can reduce the rate of load loss on the packing gland and set. The stored energy from the disc springs can compensate for the expansion and contraction that occurs during temperature cycling and improve sealing life of the packing set. These washer-shaped springs are added to the bolt, under the nut, and then tightened to the manufacturer's recommended torque value (see Figure 2).
Methods of Applying Torque
There are generally two methods of applying torque based on packing construction. Braided packings are most common and traditional. Die-formed rings are engineered and readily available for higher performance requirements. The method of applying torque for braided packing is to tighten the gland nuts until heavy resistance to wrenching is felt. The method for die-formed rings is to use a calibrated torque wrench. The gland nuts are torqued to the manufacturers' recommended value. Nuts and studs should be well lubricated, unless otherwise specified.In either case, the torque felt or measured can be incorrect because of the condition of the nut and stud threads and/or operator error. Corrosion, solid contaminants, nicks, burrs or otherwise damaged threads give an inaccurate feel or measurement when determining the applied torque.
Disc springs offer the user the advantage that the proper torque can be set by a height measurement of the spring set. This method simplifies and removes potential errors that can occur during torqueing of the gland nuts.
Torque Calculation
The bolt torque is dependent upon packing cross section, gland bolt diameter, packing style, sealed pressure and the number of bolts. The following equation can be used to determine appropriate bolt torque.
Best Practices
Generally accepted practices can minimize the chances of improperly torqueing the gland nuts:
Pages
