Hydraulic Institute walks you through documents and compliance.
10/30/2018
The Hydraulic Institute has received many questions regarding the U.S. Department of Energy’s (DOE) Energy Conservation Standard for certain clean water pumps, which will require compliance by early 2020. This edition of HI Pump FAQs addresses several of those questions. For a full list of FAQs on this topic, visit pumps.org/doerulemaking. Note: Dedicated purpose pool pumps and circulator pumps were considered under separate negotiation. These questions do not address dedicated purpose pool pumps or circulator pumps.
Where can I get a copy of the final regulations?
There are two rules that were published into law. Energy conservation program: The energy conservation standard for pumps can be found by clicking here. Energy conservation program: The test procedure for pumps can be found by clicking here. Additionally, the regulatory text for the standard, test procedure and certification can be found in the Electronic Code of Federal Regulations (e-CFR) at: 1. Go here: ecfr.gov, under Title 10, Chapter II, Subchapter D, Part 431 2. Go here: ecfr.gov, under Title 10, Chapter II, Subchapter D, Part 429When do I need to comply with the Energy Conservations Standard and Test Procedure for Pumps?
On Jan. 25 and 26, 2016, the DOE published the final rules in the Federal Register for the Energy Conservation Standard and Test Procedure for Pumps. These rules became effective on March 28, 2016. Compliance is required on Jan. 27, 2020. The annual filing requirements are as follows:- Certification reports are due Sept. 1 of each year.
 - The submittal procedure is yet to be determined.
What pump types are included in the scope of the regulations?
The scope of the standards are specified at 10 CFR 431.464 and 10 CFR 431.465, respectively. In summary: 1. Five types of “clean water” rotodynamic pumps at two nominal speeds for each type have defined standard levels. 2. “Clean water pump” means a pump that is designed for use in pumping water with a maximum nonabsorbent free solid content of 0.016 pounds per cubic foot, and with a maximum dissolved solid content of 3.1 pounds per cubic foot. This is provided that the total gas content of the water does not exceed the saturation volume, and disregarding any additives necessary to prevent the water from freezing at a minimum of 14 F. 3. Each pump type, or equipment category, is defined in the uniform test procedure. The covered types are:- end suction closed coupled (ESCC)
 - end suction frame mounted (ESFM)
 - in-line (IL)
 - radially split multistage in-line diffuser casing (RSV)
 - submersible turbine (ST)
