They are the preferred driver for low speed and high horsepower applications
02/28/2019
Q: Why are synchronous motors used for the large pumps in my facility but not small pumps? A: A type of electric motor used in pumping applications is synchronous. As the name suggests, the rotation of the shaft is synchronized with the frequency of the supply current. This is different than the most common pump driver, which is the induction motor that has a shaft that rotates at a speed less than the synchronous pole speed.
Image 1. Synchronous motor general areas of application (Image courtesy of HI)
