The project includes initiatives and first-of-its-kind technology that move the plant toward energy independence.
CNP Technology Water and Biosolids Corporation
09/14/2016
Image 1. Pumps and heat exchanger linked to the reactor as part of the process to capture and transfer methane for reuse as biogas.  (Images courtesy of CNP Technology Water and Biosolids Corporation)Putting Advanced Technology to Work
The Kenosha Water Utility provides water and wastewater services to more than 100,000 in the greater Kenosha metropolitan area. The plant’s energy-saving initiative includes the Kenosha Water Utility, plant officials and solution providers. Also key to the partnership is the company that designed and implemented individual technologies that ensure overall success as part of the biosolids-handling system process. The process at the treatment plant begins when sludge is introduced into one of two thickening centrifuges, including a primary sludge-thickening centrifuge and a waste-activated sludge-thickening centrifuge. Both thickeners create a higher solids concentration (or lower liquids concentration). The thicker concentration of solids, in turn, allows the plant to operate fewer anaerobic digestion tanks, which lessens the need for thermal and electrical energy. The challenge with waste-activated sludge is that it is not readily digestible because of a more complex cell structure than primary sludge. To tackle this, the plant incorporated a thermo-chemical hydrolysis process. This system leverages thermal energy and sodium hydroxide to break down the cell walls of the microorganisms in waste-activated sludge. This renders the sludge more digestible by anaerobic digesters, which produces additional methane from waste-activated sludge that would otherwise be unattainable. The system operates at a much lower temperature, so less heat is needed for the process and the heat transfer is much simpler. Another advantage is that all the thermal energy necessary to facilitate the hydrolysis process is transferred into the anaerobic digester, maximizing the system’s thermal efficiency.More Fuel for the System’s CHP Units
The additional methane allows for more electricity and heat production with the treatment plant’s two combined heat and power units. Following the hydrolysis process, the waste-activated sludge is blended with the thickened primary sludge before it is transferred to the system’s anaerobic digesters. The combined heat and power-generated thermal energy supplies heat to the thermo-chemical hydrolysis system and the plant’s belt dryer. The plant is able to dry the biosolids to more than 90 percent solids concentration, minimizing the volume of biosolids to be disposed of while also achieving Class A Biosolids that can be used for beneficial purposes rather than stored in a landfill. The heat generated in the process is also used for the anaerobic digesters and central plant-heating loop, further lowering energy costs. The combined heat and power units each produce 330 kilowatts of continuous power—enough to power all equipment in the process as well as provide supplemental power to the rest of the plant.
Image 2. The centrifuge room at the Kenosha Wastewater Treatment Plant. Pictured are the plant’s three centrifuges including a pair of thickeners for primary sludge and waste-activated sludge, and a dewatering centrifuge. Synergistic Approach to Plant Efficiencies
While the thermo-chemical hydrolysis system and the combined heat and power units are vital to the energy initiative, a number of other systems make up the synergistic approach that allows the treatment plant to reach its goals. These other systems include the following:- Mechanical hydraulic mixing system: It allows for more even heating of the contents, increases the volatile solids reduction and increases the volume of methane produced.
 - Biogas conditioning system: It removes the moisture and particulates within the biogas and lowers the level of siloxane to ensure clean gas is fed to the combined heat and power units.
 - Thickening centrifuges: Together, two thickening centrifuges reduce the liquid volume of the sludge stream and thicken it before it enters the primary anaerobic digesters. Less water is sent to the digesters, which reduces the number of digesters required from six (four primary and two secondary) to three (two primary and one secondary) for substantial heat and energy savings. The thickeners also save considerable space when compared with an older dissolved air floatation thickening (DAFT) system the plant replaced. The centrifuge used in the waste-activated sludge-thickening process saves the plant approximately $140,000 annually and earned a full return on investment (ROI) in 2.5 years.
 - Dewatering centrifuge: Installed in 2010, a dewatering centrifuge removes liquid from the digested sludge to take the biosolids to a 28-30 percent solids concentration. The centrifuge replaced three plate and frame presses that used lime and ferric chloride to facilitate the dewatering process. This change saves the plant hundreds of thousands of dollars per year. This resulted in an ROI of less than one year. Additionally, the plant no longer needs a full-time employee to oversee the plate and frame press operation. The centrifuge consumes three times less floor space than the system it replaced.
 - Low temperature belt dryer:The belt dryer further dries the dewatered biosolids to a 90 percent solids concentration, reducing biosolids by two-thirds. It also qualifies the biosolids as Class A Biosolids so they can be land-applied—meeting federal pollutant and pathogen requirements for land application and surface disposal. Based on 2012 data, the disposal cost at the landfill was roughly $340,000 annually. A Class A Biosolids classification makes it cost-neutral with potential as a revenue source.
