End users frequently ask me, “How long will the pump operate?” Of course, my answer is, “It depends.” As an engineer for a large pump manufacturer in the late 1970s, I was troubleshooting a pump issue at a Midwest power plant, where a broken cast steel piece required replacement. The user was upset because the part was not covered under warranty. With the exception of a few overhauls for wear rings and bearings every 10 years, the pump had been operating 24/7 for more than 45 years. The pump was designed to operate for a long time, and the user operated and maintained the pump in a manner that resulted in a half-century of trouble-free operation. In the overall equation for reliable pump life expectancy, almost every factor is dependent on the end user—specifically, how the pump is operated and maintained. As an example, a standard L-frame American National Standards Institute (ANSI) pump can be expected to operate for 15 to 20 years—and in many cases longer than 25 years—if it is properly maintained and operated near the best/design operating point. A high-horsepower multistage diffusor pump in boiler feed service can be expected to deliver 40 years of service or more. For a given pump design, what are some of the factors that end users can control to prolong a pump’s life? While this is not an exhaustive list, the following 13 notable factors are important considerations for extending pump life.
Common Pumping Mistakes
Summit Pump Inc.
12/05/2016
