Addressing Effluent Transfer Problems With Progressive Cavity Pumps
How progressive cavity technology helped a Malaysian palm oil mill solve its POME transfer crisis.
Roto Pumps
In the heart of Malaysia, a palm oil mill found itself grappling with a growing operational threat. Though capable of processing 60 metric tons of fresh fruit bunches per hour, the mill was repeatedly hobbled by a hidden problem: inefficient and unreliable palm oil mill effluent (POME) transfer. What started as a maintenance nuisance ballooned into a critical bottleneck threatening the mill’s capacity, environmental compliance and long-term profitability.
The Problem
POME is no ordinary effluent. A byproduct of palm oil production, it is a hot, acidic and abrasive slurry filled with organic solids, sand and biomass residue. When pumped through high-speed centrifugal systems, the results were catastrophic. The impellers and casings corroded within months. Leaks developed rapidly. Downtime became routine, and operators were forced to reduce throughput to avoid overflows that could violate strict Malaysian environmental regulations. Time and money were being lost on repairs, spare parts and emergency maintenance, and there was the constant risk of environmental penalties if the POME overflowed into untreated lagoons.
A New Direction
With recurring breakdowns costing up to 50,000 Malaysian ringgit (RM) annually in parts, labor and downtime, the mill’s engineers sought a solution. An in-depth site study, a fluid analysis and various technical consultations were performed. The goal was not just to swap pumps but to reengineer the system for resilience.
IMAGE 1: The impact of the progressive cavity pump installation was both immediate and far-reaching. What began as an effort to eliminate frequent breakdowns quickly evolved into a strategic upgrade that transformed the mill’s POME handling operations. (Images courtesy of Roto Pumps)
The Technology
The solution came in the form of a progressive cavity pump with integrated dry running protection (DRP). Progressive cavity pumps rotate slowly—around 200 to 400 rotations per minute (rpm)—making them ideal for abrasive, viscous or shear-sensitive fluids like POME.
Here is how the technology works:
  • A single helical rotor rotates within a double-threaded elastomeric stator, creating progressing cavities that transport fluid from suction to discharge.
  • The motion is smooth, nonpulsating and capable of handling entrapped air, suspended solids and variable fluid consistencies.
  • The low-shear mechanism preserves the biological microbes in POME that are essential for effective anaerobic treatment downstream.
In pumps like these, the DRP system acts like an insurance policy. If the pump runs dry and the stator overheats—a common failure point in POME operations—it automatically shuts down to prevent damage.
Implementation
Installing the pump was not without its challenges. The progressive cavity pump had a larger footprint than the original centrifugal system. Worse, the installation site featured soft, damp soil—raising concerns about subsidence.
To address these challenges, a secondary site visit was done to assess structural constraints, soil compaction was carried out and a reinforced concrete platform was constructed to support the pump’s weight and vibration load.
With the mechanical installation complete, on-site personnel were trained in system operation and DRP calibration.
The Results
From the moment the new pump went online, operators noticed a difference. The reduced operating speed—just 200 to 400 rpm compared to the 1,400 rpm of the former centrifugal units—meant less mechanical stress, less vibration and dramatically lower wear rates on internal components. This alone translated into measurable gains: The mill no longer faced biannual impeller and casing replacements, nor the recurring costs of emergency part orders and labor-intensive repair work.
The mill now saves up to RM50,000 per year on spare parts and maintenance-related labor. Beyond the financial benefit, the shift also freed up valuable technician time. Instead of reacting to leaks and failures, skilled personnel could focus on preventive maintenance, system optimization and energy management—areas that directly enhance long-term operational efficiency.
Energy consumption was another area of improvement. Centrifugal pumps operating at high speeds tend to draw more power, especially when struggling to handle viscous or solids-laden fluids like POME. With the switch to progressive cavity technology, the lower-speed operation reduced electrical demand while still delivering consistent, uninterrupted flow. As a result, the mill achieved energy savings without compromising performance.
Perhaps even more critically, the reliability of the new pump stabilized the entire POME treatment process. Previously, inconsistent transfer rates and sudden pump failures led to fluctuating retention times in the treatment ponds—posing a risk of overflow, environmental noncompliance and even production slowdowns. The new system’s ability to maintain steady, clog-free flow helped ensure that POME moved efficiently through each stage of treatment, from anaerobic to aerobic ponds, supporting regulatory compliance and environmental stewardship.
The enhanced stability also led to operational predictability. With fewer unplanned shutdowns and pump alarms, mill management could better forecast maintenance schedules and allocate resources more effectively. And because the pump system came equipped with DRP, the risk of stator damage from overheating—a common failure point in traditional systems—was essentially eliminated. The DRP feature’s automatic temperature monitoring and shutoff mechanism added an extra layer of protection and peace of mind.
Overall, the project proved to be more than a cost-saving exercise—it was a platform for continuous improvement. Improved uptime, reduced energy use, streamlined operations and strengthened compliance all combined to support the mill’s broader goals for sustainable palm  oil processing.
IMAGE 2: With the switch to progressive cavity technology, the lower-speed operation reduced electrical demand while still delivering consistent, uninterrupted flow. As a result, the mill achieved energy savings without compromising performance.
The Benefits of Progressive Cavity Pumps in POME Applications
At the palm oil mill, the centrifugal units originally in use were operating at speeds as high as 1,400 rpm. This high-speed operation accelerated wear and tear on critical components like impellers and casings, which frequently succumbed to corrosion and erosion due to the effluent’s high temperature, acidity and solid content.
The new progressive cavity pumps operate at a much slower speed, drastically reducing internal friction and prolonging the life of the components. The low operating speed not only minimizes wear but also contributes to reduced energy consumption. Progressive cavity pumps also eliminate the need for additional components such as check valves. Their rotor-stator design forms sealed cavities that inherently prevent backflow and maintain a consistent, metered flow.
Another critical difference lies in how each pump handles suspended solids. Centrifugal pumps can be susceptible to clogging when solids are present in the fluid—especially when these include sand and fibrous biomass, as found in POME. Progressive cavity pumps are specifically designed to move viscous, solids-laden fluids without clogging, making them useful in palm oil mill operations. Moreover, the low-shear pumping action of progressive cavity technology ensures the biological integrity of the effluent is preserved, a crucial factor for effective anaerobic treatment.
The new progressive cavity pump installation now runs smoothly with just biannual inspections. The result is less downtime, fewer spare part replacements and lower labor costs.
Broader Impacts: Aligning With Sustainability Goals
Palm oil has long faced scrutiny over its environmental footprint. But the industry is making quiet strides toward more sustainable practices. Efficient, leak-free transfer of effluent plays a small but vital role in this evolution.
The switch to progressive cavity pumps allowed the palm oil mill to reduce waste, avoid chemical spills and enable better downstream treatment, aligning with Malaysia’s environmental mandates and supporting the mill’s broader sustainability goals.
This case offers more than a technical fix—it is a case study in proactive problem-solving, thoughtful engineering and long-term vision. As palm oil producers across Southeast Asia face mounting environmental pressures and aging infrastructure, the switch from centrifugal to progressive cavity technology could represent a path forward.
For more on progressive cavity pumps, visit pumpsandsystems.com/tags/progressive-cavity-pumps.
