Activated Carbon Image
The benefits of activated carbon in drinking water safety.
Arq Inc.
Drinking water utilities are increasingly taking an all-hands-on-deck approach to contamination management. As new contaminants are identified and regulated, diverse, targeted treatment options are emerging at an accelerating pace, allowing utilities to respond effectively to variations in source water, regulatory requirements and performance expectations. The complexity of modern drinking water treatment and the prioritization of public health demands a layered strategy of multiple available technologies rather than a single-solution tactic.
Even with newer treatment innovations, activated carbon (AC) remains a trusted tool due to its cost-effectiveness for a broad range of contaminants. Through adsorption, AC has long been effective at improving water quality by removing taste- and odor-causing compounds, industrial organic pollutants and agricultural contaminants like herbicides and pesticides. Growing concern over emerging contaminants such as per- and polyfluoroalkyl substances (PFAS), pharmaceuticals and other trace organics has not left this technology behind; instead, it has driven continued innovation, with scientific advances refining and extending the effectiveness of activated carbon.
The Mechanics of Adsorption & Activated Carbon
With absorption, molecules enter the bulk volume of another material (the absorbent) and become uniformly distributed throughout that material. With adsorption, however, molecules cling to the surface of the material (the adsorbent) and are thereby removed from water.
Activated carbon is particularly well-suited as an adsorbent because it combines extremely high surface area with surface chemistry that favors organic molecules. Through high-temperature steam treatment, carbon is riddled with micro-, meso- and macropores that create hundreds to thousands of square meters of surface area in a very small mass. Contaminants diffuse into these pores and are held onto the carbon’s surfaces by physical (Van der Waals) and chemical forces.
Advantages of Powdered Activated Carbon
Powdered activated carbon (PAC) offers flexibility and responsiveness in water treatment because it allows utilities to directly manage variability in water quality. Because PAC is added directly to the water as a fine powder, it provides rapid adsorption kinetics and can be dosed precisely to match changing contaminant loads, seasonal conditions or short-term water quality events. PAC is highly effective for a range of contaminants because of its small particle size and tunable surface chemistry and pore structure.
PAC particles expose adsorption sites almost immediately upon contact, enabling rapid uptake of dissolved organic contaminants without the long empty-bed contact times required by fixed media systems. This is especially valuable when raw water conditions change due to runoff events, algal blooms or episodic contamination. PAC can be injected at multiple points within a treatment system, including reservoirs, basins and existing process units, making it particularly valuable during emergency or disaster response scenarios. PAC can remain operational even if portions of a facility are offline, overwhelmed or damaged, providing a resilient treatment option when rapid response is critical.
From a surface chemistry perspective, PAC is well suited to interacting with the diverse organic matter present in natural waters. Its largely hydrophobic carbon surface preferentially attracts nonpolar and moderately polar organics, while oxygen-containing functional groups influence adsorption strength and selectivity. Utilities can select PAC grades optimized for higher micropore volume to target small, trace organics or a broader pore distribution to manage competing natural organic matter (NOM). Because temperature, pH and NOM concentration directly affect adsorption equilibria, PAC’s dose-based application allows operators to compensate in real time by simply adjusting feed rates.
PAC’s pore structure further supports performance under dynamic conditions. Micropores provide high adsorption capacity for low-molecular-weight contaminants, while mesopores improve diffusion and reduce fouling by larger organic molecules. This hierarchical pore network helps PAC remain effective even in waters with elevated organic loading.
When installed upstream of clarification, filtration or membranes, PAC reduces organic interference, protects downstream processes and helps other functions in the treatment train perform better. For example, when dosed in a system that already uses granular activated carbon (GAC), PAC can rein in contamination spikes and extend the life of downstream GAC.
Stored properly, PAC has a long shelf life and can be stockpiled as part of a utility’s emergency preparedness and disaster response planning, enabling rapid deployment without reliance on just-in-time delivery during disruptive events.
PAC Application in Conventional Treatment Processes
In surface water treatment plants, PAC is typically applied at well-established feed points so it can fully interact with the raw water and be incorporated into the solids removal process. Utilities may operate PAC systems continuously at low doses to manage baseline organic loading or intermittently in response to specific or sudden events. When properly integrated, PAC works synergistically with coagulation and flocculation, adsorbing dissolved organics that might otherwise interfere with particle aggregation. The PAC and associated contaminants are then captured with the floc and removed during sedimentation and filtration, reducing organic precursors entering disinfection and delivering downstream benefits in disinfection efficiency and disinfection byproduct control.
Many utilities already operate PAC systems for taste and odor control, which allows emerging contaminant treatment like PFAS mitigation to be implemented through relatively simple dosing adjustments or by transitioning to higher-performance carbon grades rather than introducing new treatment processes.
Operational & Design Considerations for Utilities
When evaluating PAC for utility applications, operational and design decisions center on dose selection, performance verification and downstream impacts. PAC dosage must be optimized to balance contaminant removal with cost, recognizing that adsorption efficiency is strongly influenced by   source water characteristics such as organic matter composition, temperature and seasonal variability. Utilities commonly rely on jar testing and, where warranted, pilot studies to assess PAC type, dose and contact time under representative conditions.
Ongoing performance monitoring helps confirm treatment objectives are being met. Also, utilities must account for residuals management as PAC increases solids loading and can affect sludge handling, dewatering and disposal practices within the treatment process.
Utilities with sustainability objectives might consider PAC produced domestically and from renewable or reclaimed feedstocks as part of broader environmental and supply-chain resilience goals.
The Role of PAC in Regulatory Compliance
When properly selected and dosed, high-performing PAC has demonstrated the ability to reduce long-chain PFAS concentrations to very low or nondetectable levels, particularly when pore structure and surface chemistry are matched to target compounds. As utilities prepare for compliance with the new PFAS Safe Drinking Water Act regulations, PAC provides a practical near-term option due to its ability to adsorb long-chain PFAS, including perfluorooctanoic acid (PFOA) and perfluorooctanoic sulfonate (PFOS). These two compounds have been identified by the current Environmental Protection Agency (EPA) administration as priority contaminants that will remain regulated, even if other elements of the PFAS regulatory framework are revised.
Within a utility’s broad compliance strategy, PAC is well suited for addressing episodic contamination events, such as short-term source water impacts, algal toxin occurrences or sudden contaminant detections. From a regulatory perspective, PAC offers utilities operational flexibility as guidance and standards continue to evolve, allowing treatment responses to be adjusted without committing to permanent infrastructure changes. PAC can support immediate compliance targets and public health protection while longer-term treatment strategies are evaluated or implemented.
Modern Water Protection
As drinking water utilities navigate increasing contaminant complexity, regulatory uncertainty and source water variability, PAC remains an adaptable tool within modern treatment strategies. Grounded in well-understood adsorption science, PAC offers rapid response capability, operational flexibility and compatibility with existing infrastructure. Whether applied for routine organic control, episodic contamination events or near-term PFAS compliance, PAC allows utilities to manage risk effectively while preserving optionality for longer-term investments.
