The Pomona Valley Hospital Medical Center was spending between $4,500 and $8,500 per incident to remove solids from its sewage ejection pits.
06/23/2016
Because they clog pumps, non-dispersible wipes have become a source of anguish for many maintenance teams. When pumps that run in critical applications become clogged, the cost to repair or replace those pumps escalates. These excessive maintenance expenses have been shouldered by many hospitals across the U.S. that have experienced a rapid increase in non-dispersible materials entering their sewage systems.
Image 1. Between 2008 and 2014, the Pomona Valley Hospital Medical Center's sewage ejection pumps needed to be rebuilt and replaced several times. (Images courtesy of BJM Pumps)Looking for a Solution
Peter Kersten, stationary engineer for PVHMC, began researching grinder and shredder pumps that were available on the market and decided on a submersible shredder pump designed to shred almost everything—from rubber chickens to running shoes. He presented the pump to his bosses and explained how a submersible shredder would meet their critical requirements:- The pumps needed to be able to shred the disposable wipes and rags that were pushed into the sewage ejection pits. The sewage ejection pits needed to stay clear of fibrous, floating debris to prevent clogs and avoid emergency situations.
 - The pumps needed to be able to operate reliably to avoid extra maintenance expenses.
Results
Once the PVHMC decision makers were on board with the selection, two of the submersible shredder pumps were installed in a duplex arrangement inside the 16-foot-deep sewage ejection pit. During installation, under the direction of Cortech Service Manager Mark Fox, Cortech's on-site technicians installed a lifting chain, electrical wiring to a 15-amp breaker for the duplex control panel and the seal moisture-detection relay, and new stainless steel check valves.
Image 2. The pumps operating in the Pomona Valley Hospital Medical Center's sewage ejection pits were consistently becoming clogged with wipes and other materials not designed to be flushed through a sewage system.
