A German pharmaceutical facility upgraded its pumps to efficiently handle solvents.
12/09/2014
Established in 1896, the F. Hoffmann-La Roche Ltd. company, today known as Roche, is recognized as the world’s fifth largest pharmaceutical company. It operates in locations around the globe, including the U.S., Ireland, Germany and Pakistan. Roche’s operations are divided into two core businesses: Pharmaceuticals and Diagnostics. The Roche Diagnostics GmbH facility in Penzberg, Germany, is home to both pharmaceutical and diagnostics operations. This makes it one of the largest biotechnology research centers in Europe. The facility produces the active ingredients used in almost all the pharmaceuticals and reagents that Roche manufactures.
Solvent Storage
The Penzberg facility has been in operation for 40 years, employs more than 5,100 people and includes about 60 buildings. Large volumes of raw ingredients and finished pharmaceutical products are constantly on the move. The solvents used in the pharmaceutical production process are among the most critical fluids at the facility. “Roche Diagnostics produces lots of medicines and is a very big pharmaceutical factory,” said Florian Habeck, assistant tank manager at Roche Diagnostics. “We must have solvents to produce our products. We buy the solvents from manufacturers, and after using them for production, we send the used solvents to underground storage tanks.” Florian Habeck, assistant tank manager for Roche Diagnostics GmbH, stands next to the facility’s AODD pump, known around the plant as “Big Bertha.” (Images courtesy of Almatec)
Florian Habeck, assistant tank manager for Roche Diagnostics GmbH, stands next to the facility’s AODD pump, known around the plant as “Big Bertha.” (Images courtesy of Almatec) Founded in 1896, Roche has grown into the world’s fifth largest pharmaceutical manufacturer.
Founded in 1896, Roche has grown into the world’s fifth largest pharmaceutical manufacturer.AODD Pumps
Roche’s solvent-handling operation requires a pump that can safely and efficiently transfer potentially dangerous chemicals at a high volume. Since the late 1980s, Roche has relied on plastic air-operated double-diaphragm (AODD) pump technology to conduct solvent transfer. During their 25 years at the site, the pumps successfully moved liquids with particles in them while maintaining a smooth flow. The underground tanks that store used solvents at the Roche Diagnostics facility range in size from 60 to 100 cubic meters (15,800 to 26,400 gallons) and can be accessed from the surface.
The underground tanks that store used solvents at the Roche Diagnostics facility range in size from 60 to 100 cubic meters (15,800 to 26,400 gallons) and can be accessed from the surface.Safe, Reliable Flow
The pump—known to Roche personnel as “Big Bertha”—has a maximum flow rate of 48 m3/hour—12,600 gallons per hour (gph). Because the piping runs that are connected to the truck-loading area are 13 to 16 feet (4 to 5 meters) long, the pump’s suction line was outfitted with a pulsation damper. This allows the pump to produce a virtually uniform flow. Roche Diagnostics’ used-solvent storage tanks are monitored from a dedicated on-site computer room that gives the operator real-time information regarding liquid levels and potential alarm conditions.
Roche Diagnostics’ used-solvent storage tanks are monitored from a dedicated on-site computer room that gives the operator real-time information regarding liquid levels and potential alarm conditions. With a maximum flow rate of 48 m3/hr, the Roche facility’s AODD pump meets the facility’s need for a pump that can safely fill a 25-m3 (6,600-gallon) tank truck with used solvents in about 30 minutes.
