Bearing seals and isolators can eliminate leaks and contaminants
03/07/2019
What methods can be used to maintain lubrication oil quantity and quality? For oil bath lubrication, quantity of oil can always be adjusted by adding oil to maintain the manufacturer’s recommended level. However, another approach to maintain the proper quantity of oil is with bearing housing seals. When properly applied, bearing seals can eliminate lubrication leaks from the housing and help maintain recommended oil levels.
Image 1. Common bearing housing seals (Images courtesy of Hydraulic Institute)
Image 2. Two examples of shut-off devices used in labyrinth seals.
