New & Notable Technology: February 2026
A look at new and notable products in the world of pumps and systems.
1. HYGIENIC PUMPS
CleanPlus line - Unibloc Hygienic Technologies
The CleanPlus line of hygienic pumps from Unibloc Hygienic Technologies features bolt-free rotors that eliminate downtime and pump damage caused by improper tightening. These pumps can be used for cosmetic, pharmaceutical and tanker truck applications that require durable, sanitary operations. Suitable for both CIP and COP applications, they reduce maintenance times with their easy-to-disassemble design. They come in port sizes ranging from 1-inch to 8-inch and, depending on the model, can pump up to 500 gpm (1,900 liters per minute). They may be used with product as hot as 400 F (204 C).
2. PROCESS VALVES
ARI-Armaturen USA’s ZETRIX series of metal-seated process valves
ARI-Armaturen USA’s ZETRIX series of metal-seated process valves are engineered for durability, safety and zero-leakage performance. They are built for demanding service conditions involving temperature extremes, pressure swings and severe mechanical stress. ZETRIX valves feature a thermal balancing, self-aligning seat ring that guarantees zero leakage, even at elevated temperatures or during rapid thermal cycling. A stellited seat provides long-lasting protection against wear and erosion. Standard spare parts kit includes a lamellar seal ring, graphite packing unit and two spiral-wound gaskets for simplified inventory and service planning.
3. VERTICAL TURBINE PUMPS
National Pump Company’s line of API-610 type VS-0 submersible, VS-1 sump and VS-6 canned vertical turbine pumps for the petroleum market
National Pump Company’s line of API-610 type VS-0 submersible, VS-1 sump and VS-6 canned vertical turbine pumps for the petroleum market conform to the latest edition of the API-610 standard. Ranging from 6-inch to 30-inch hydraulics, these pumps feature flows to 25,000 gpm, heads to 2,000 pounds per square inch gauge (4,620 feet) and up to 2,500 horsepower. Pumps include standard or thrust balanced hydraulic designs and engineered fabricated steel discharge heads and column assemblies. Pump components are available in all API material classes, including cast and ductile iron (S-1 to S-6), steels, stainless steels, duplex and super duplex.
4. VACUUM PUMPS
NAVAC EcoDrive series vacuum pumps from Mass-Vac Inc.
The NAVAC EcoDrive series vacuum pumps from Mass-Vac Inc. are dual-stage oil-sealed rotary vane vacuum pumps featuring variable-frequency permanent magnet DC motors that run quietly and require 40% less energy than conventional vacuum pumps. These small vacuum pumps incorporate a diamond-like carbide coating on all internal parts for optimum corrosion resistance and come in six models with capacities from 2.5 CFM for the model ED4 and up to 18 CFM for the model ED30.
5. INDUSTRIAL CONTROL RELAYS
WAGO Corporation’s 2585 series relays
WAGO Corporation’s 2585 series relays are designed to deliver essential switching functions with outstanding efficiency and versatility for general industrial control applications. The 2585 series features both sockets and elementary relays, available individually or as preassembled kits. With nominal input voltages ranging from 12 VDC to 230 VAC and options for two or four changeover contacts, these relays are engineered to meet a wide variety of application needs.
6. HUMIDITY SENSORS
ProSense HUM series of humidity sensors from AutomationDirect
The ProSense HUM series of humidity sensors from AutomationDirect provides reliable temperature and relative humidity (RH) measurements for HVAC, cleanroom and general industrial applications. These sensors offer versatile mounting options and wide measurement ranges (-4 to 140 F, 0 to 99.9% RH), with select models providing a seven-segment display for quick, at-a-glance monitoring. Duct mount sensors include probes that mount directly in air ducts for HVAC and ventilation. Wall/duct models allow flexible installation, with probes that can be mounted through a duct or suspended freely from a wall. Compact wall-mount room sensors are easy to install and provide ambient temperature and RH measurement.
7. DIGITAL TWIN SOFTWARE
Digital Twin Composer from Siemens
The Digital Twin Composer from Siemens is a software solution that enables industrial companies to combine 2D and 3D digital twin data from a comprehensive digital twin with physical real-time information in a managed, secure, real-time, photorealistic visual scene built using NVIDIA Omniverse libraries. Users can rapidly build and maintain this global environment, containing all aspects of their product or production data (both virtual and physical) in a secure and managed high-fidelity 3D experience throughout the life cycle of the product, process or facility. Digital Twin Composer provides contextualized, real-time insights and intelligence, enabling users to visualize, interact with and iterate on any product, process or factory in its real-world context before physical design or construction.
8. NONCLOG SUBMERSIBLE PUMPS
ShinMaywa (America), Ltd.’s CNWX series of heavy-duty, nonclog submersible pumps
ShinMaywa (America), Ltd.’s CNWX series of heavy-duty, nonclog submersible pumps are ideal for industrial and municipal wastewater markets. These pumps feature a single-vane, nonclog impeller design that incorporates a helix-formed passage at the inlet, which is connected to the single-vane nonclog passage. This design virtually eliminates clogging, plugging and entangling of fibrous materials, resulting in a reduction of maintenance costs and electrical power consumption.
9. TANK-CLEANING NOZZLE
BETE’s HydroWhirl Poseidon
BETE’s HydroWhirl Poseidon cleans effectively in tanks containing harsh chemicals or stubborn substances. This slow-spinning tank cleaning nozzle provides complete 360-degree coverage with longer dwell time on target surfaces. It is ideal for use in corrosive chemical environments, chemical processing tanks, food and beverage processes, IBC totes and more. Crafted from PFTE, the HydroWhirl is 100% corrosion-resistant and offers the lowest friction coefficient of any material, enabling faster cleaning with less water compared to static spray options. The material construction is also FDA-compliant and is suitable for use in clean-in-place and food-safe applications.
10. SOLIDS-HANDLING PUMPS
Pentair’s Fairbanks Nijhuis XRW series solids-handling pumps
Pentair’s Fairbanks Nijhuis XRW series solids-handling pumps have been engineered to help reduce clogging and maintain peak hydraulic performance. The high-efficiency design reduces capacity drift while ensuring smooth operation and minimizing vibration. Features include permanently lubricated bearings in a compact bracket for easier handling, a double mechanical seal for increased durability and adjustable durable wear rings. Fairbanks Nijhuis XRW series pumps are also compatible with IEC B5 motors as a standard option, offering flexibility in motor brand selection.
11. SUBMERSIBLE WELL PUMPS
Franklin Electric’s FS series submersible well pump
Franklin Electric’s FS series submersible well pump features floating stage hydraulics that improve efficiency and minimize wear even when pumping abrasives. Intended for potable drinking water applications where a submersible pump provides the best output, the FS series line is designed to enhance performance with minimal internal leakage or restriction. Each FS series submersible well pump floating stage design also reduces the vertical downthrust applied on the submersible motor and increases the overall performance of the water system. Available in various performance ranges: 5, 8, 10, 12, 16, 22 or 26 gpm with horsepower ranges from 1/2 to 5.
12. PORTABLE BYPASS PUMP SYSTEMS
Vaughan’s series of portable bypass pump system options
Vaughan’s series of portable bypass pump system options can be used for tough solids reduction applications or low shear solids handling in temporary or permanent situations. Pumps are supplied on a trailer or skid-mounted platform powered by either diesel, hydraulic or electric drive motors. Pump options include: dry prime horizontal end suction chopper pumps in 3-inch to 16-inch models; dry prime horizontal end-suction triton screw pumps in 3-inch to 12-inch models; and wet prime self-priming chopper pumps in 4-inch to 10-inch models.
