Pump failure can cause costly downtime, disrupt entire operations and lead to expensive repairs or even catastrophic system failures (Photo licensed by Samotics/Adobe Stock)
Common methods for detecting and preventing pump failure.
Samotics
For industries that rely on fluid movement—such as water treatment, oil and gas, agriculture and manufacturing—pump failures are more than just an inconvenience. A single breakdown can cause costly downtime, disrupt entire operations and lead to expensive repairs or even catastrophic system failures.
To keep pumps running efficiently, it is vital to understand why they fail in the first place. Recognizing early warning
signs and implementing proactive maintenance strategies can significantly extend the lifespan of equipment while ensuring smooth operations.
Common Causes of Pump Failure
Mechanical seal leakage: Most leakages take place at the interface between the two seal faces, but leakages also occasionally come from the secondary sealing area. Reasons for mechanical seal leakage include dry running, thermal distortion and misalignment of seal rings, to name a few.
Bearing issues: According to a technical report by the RKB Bearing Industries Group, the most common reason for bearing failure is improper lubrication (80%) causing overheating. Other causes include improper bearing selection, overload, fatigue and more.
Impeller wear and tear: One of the most common reasons for impeller wear and tear is erosion, but it can also result from an improperly sized pump, which can lead to an imbalance of pressure.
Coupling-related issues: Most coupling failures happen due to misalignment, overload, uncommon environmental causes, torsional vibration or improper lubrication.
Operational errors: Even the most advanced pump will not last if it is run outside its intended parameters. Improper startup and shutdown, overloading or ignoring manufacturer guidelines can lead to overheating, excessive wear and dangerous malfunctions. For submersible pumps, failing to maintain adequate submersion levels can cause dry running, leading to seal failure and motor burnout.
Power supply issues: A stable power supply is critical for pump performance. Voltage fluctuations, power surges and unexpected outages can wreak havoc on motors, causing them to overheat, operate inefficiently or fail altogether.
Pump failures do not happen by chance—there is always a reason. Whether due to neglect, environmental conditions
or operational mistakes, breakdowns can be costly and disruptive. Understanding the root causes of pump failure is the first step in preventing them.
Detecting Early Signs of Pump Failure
Pump failures do not happen overnight—there are always warning signs:
  • Unusual noises: Grinding, whining or banging sounds often signal cavitation, worn bearings or misalignment.
  • Excessive vibration: Increased shaking can indicate misaligned shafts, imbalanced impellers or failing bearings.
  • Reduced flow or pressure: A sudden drop in output may be caused by blockages, air leaks or internal wear.
  • Overheating: Motors or bearings running hotter than usual suggests poor lubrication, overloading or electrical issues.
  • Leaks or seal damage: Visible leaks often point to worn-out seals or excessive internal pressure.
  • Erratic power consumption: Spikes in energy use can indicate an inefficient or struggling pump.
Routine inspections, vibration analysis and thermal monitoring can help detect these issues before they lead to failure.
Failure Modes Specific to ESPs
While all pumps face common failure risks, electrical submersible pumps (ESPs) are particularly vulnerable due to their submerged operation and intricate design. Below are some common ESP-specific vulnerabilities and how to address them.
Insulation degradation and electrical failures: Since ESPs function underwater, insulation integrity plays a major role in preventing electrical faults. Over time, exposure to high temperatures, moisture infiltration and mechanical stress can weaken insulation, increasing the risk of short circuits and motor failure. Conducting regular insulation resistance tests helps identify early-stage deterioration before it leads to downtime.
Gas locking: In oil and gas applications, ESPs are prone to gas locking, where excessive free gas in the pumped fluid disrupts flow through the impellers. This results in lost efficiency, overheating and potential damage. To combat gas locking, operators can install gas separators and adjust intake designs to improve fluid handling.
Seal failure and water ingress: Mechanical seals prevent external fluids from entering the motor, but factors like wear, pressure fluctuations and temperature changes can cause seal deterioration, leading to water intrusion and electrical malfunctions. Regular seal inspections and using pressure-equalizing devices can enhance seal longevity and reduce failure risks.
Sand and solids abrasion: ESPs in deep well and oil field applications often operate in environments with high levels of sand and abrasive particles. These materials accelerate wear on impellers, diffusers and bearings, reducing pump efficiency. Utilizing hardened components, sand screens and variable speed drives helps minimize wear and extend pump lifespan.
Pump Failure Analysis: Diagnosis & Prevention
Root cause analysis (RCA) is a structured approach used to determine the underlying cause of pump failures. By systematically investigating performance issues, maintenance records and operational data, RCA can identify key factors leading to breakdowns. Methods such as failure mode and effects analysis (FMEA) and fault tree analysis (FTA) can help diagnose recurring problems and develop corrective actions.
Electrical signature analysis (ESA) examines motor current and voltage signals to detect early signs of degradation. This method is particularly beneficial for submersible pumps, as it can reveal issues such as winding insulation breakdown, phase imbalances and mechanical misalignments, allowing for timely intervention before failures occur.
Vibration analysis analyzes vibration patterns and frequencies to help identify mechanical problems before they escalate. Unusual vibrations often signal misalignment, imbalance, bearing wear or cavitation. Regular monitoring enables maintenance teams to address these issues proactively, reducing unplanned downtime and repair costs.
Thermographic inspection utilizes infrared imaging to detect abnormal heat signatures in pump systems. Overheating components, such as bearings, seals and motor windings, often indicate excessive friction, lubrication issues or electrical faults. Regular thermal imaging surveys help identify potential failures early, allowing for corrective actions before a catastrophic breakdown occurs.
Oil and lubricant analysis is a predictive maintenance technique that assesses the condition of lubricants and detects contaminants such as metal particles, water and sludge. A change in viscosity or acidity or the presence of wear debris can signal component degradation. Regular sampling and testing help extend the life of bearings, gears and seals, reducing maintenance costs.
Cavitation detection and analysis is useful in situations involving cavitation, which occurs when vapor bubbles form and collapse within the pump, leading to erosion of impellers and reduced efficiency. Common causes include low suction pressure, high flow velocity or improper pump selection. Acoustic monitoring, pressure sensors and flow rate analysis are used to detect and mitigate cavitation, preventing long-term damage to pump components.
Wear debris analysis is a technique for assessing pump health by examining particles present in oil samples. The size, composition and quantity of metal particles help determine wear patterns and failure modes. Spectroscopy and ferrography are commonly used to classify wear types, such as adhesive, abrasive or fatigue wear, enabling proactive maintenance strategies.
Pump performance monitoring involves tracking key parameters such as flow rate, pressure, temperature and power consumption. A deviation from baseline performance data often indicates an impending failure. Implementing remote monitoring systems with real-time analytics allows for early detection of issues, optimizing pump efficiency and reliability.
Monitoring Submersible Pumps’ Condition With ESA
Submersible pumps operate in harsh and inaccessible environments, making traditional diagnostic methods like vibration analysis and thermographic inspection more challenging to implement. ESA is an effective and practical approach for monitoring the condition of submersible pumps due to the following reasons:
1. Nonintrusive monitoring
ESA analyzes electrical signals (current and voltage) from the motor without requiring physical access to the pump. Since submersible pumps are often located underwater, in wells or in hazardous areas, accessing them for vibration or thermal measurements is difficult and costly. ESA provides a remote, nonintrusive way to monitor pump health without disrupting operations.
2. Early detection of mechanical and electrical issues
ESA can detect faults before they manifest into catastrophic failures. By analyzing deviations in electrical waveforms, ESA identifies early signs of:
  • Winding insulation breakdown, leading to motor overheating and short circuits
  • Phase imbalances and voltage fluctuations, causing inefficient motor operation and premature failure
  • Rotor bar defects, indicating potential degradation in motor components
  • Mechanical misalignments and bearing wear, detected through irregular motor current variations, which correlate with mechanical stress
3. Detection of pump load and flow irregularities
Unlike vibration analysis, which primarily focuses on mechanical aspects, ESA can diagnose issues related to pump load variations and flow problems. Changes in electrical current signatures often indicate:
  • Cavitation, characterized by irregular load fluctuations and motor instability
  • Blockages in suction or discharge lines, reflected in abnormal motor current draw
  • Seal and impeller wear, increasing power consumption due to rising friction or inefficiencies
4. Unaffected by harsh environments
Since ESA relies on electrical signal analysis rather than physical sensor readings, it is unaffected by extreme temperatures, high-pressure environments or submersion in liquids. This makes it ideal for deep wells, wastewater systems, offshore applications and other difficult-to-access installations.
5. Cost-effective and scalable
Beyond its diagnostic accuracy, ESA is a highly scalable and cost-efficient solution for pump monitoring. Unlike traditional methods that require direct sensor placement, ESA provides remote insights without the need for additional hardware installations. This makes it particularly valuable for industries operating multiple submersible pumps in hard-to-reach locations.
Preventing pump failures requires a shift from routine fixes to strategic, condition-based maintenance. With tools like ESA, vibration monitoring and oil analysis, maintenance teams can catch problems early, reduce unplanned downtime and extend equipment lifespan.
For more on pump monitoring, visit pumpsandsystems.com/tags/condition-monitoring
