Rugged equipment reliably serves in a Texas in-situ recovery mine.
02/03/2015
In 2010, a rare-mineral exploration, development and production company opened an in-situ recovery (ISR) mine in South Texas. This was the first new ISR mine in the U.S. in five years. The facility extracts raw minerals from a sandstone formation and ships them to a nearby processing plant where they are refined.
The Solution
A pump distributor worked closely with the facility to arrive at a solution. After reviewing the application’s challenges in detail, a heavy-duty submersible slurry pump was selected. Engineered for maximum service life, the pump type offers robust construction and superior solids-handling capabilities. The 5-horsepower pumps have built-in agitators that fluidize solids into a slurry for complete pumping. They also have hardened components—including high-chrome iron agitators, wear plates and an impeller—to resist abrasive materials. Key features include:.jpg)
- Optimum wear resistance—All wetted parts are constructed of abrasive resistant 28 percent chrome iron (600 Brinell, 71 Rockwell C) for maximum wear life. In addition, a replaceable hardened wear plate is located on the suction side, where erosion would cause a loss of pump performance.
- Maximum solids handling capability—An integral agitator fluidizes settled solids into a slurry making them easier to pump with less chance of clogging. The semi-open impeller handles abrasive solid concentrations as high as 70 percent by weight.
- Class H motor insulation and built-in, full load amperage and temperature overload protection
- Double silicon carbide mechanical seals in a separate, oil-filled seal chamber
- Heavy-duty lip seal that provides additional protection for the mechanical seals
- Stainless steel shaft and shaft sleeve that provide maximum wear and corrosion protection
- Pump volutes cast from hardened ductile iron (300 Brinell hardness), which is twice as abrasive resistant as standard ductile iron with walls that are extra thick at the point where pumped slurry enters the discharge
