Consider fluids, operating conditions and system optimization.
Vaughan Company Inc.
02/05/2019
It is time for a new chopper pump. The need is justified and the initial budget is approved. Now it is time to determine exactly which pump model and specification will fit the need. From operating conditions to lifetime cost analysis, it is important to do the research before placing that order. Here are some key areas to keep in mind:
Know the Fluid
Modern pumping challenges include pumping fluids mixed with various solids or debris. Chopper pumps excel at pumping fluids that contain unpredictable solids that cause pump blockage in traditional nonclog pumps. Pumping coke slurry at a steel mill (with random rags or the occasional glove), food wastes, plastics or raw sewage in a lift station (with the presence of wipes and various plastics) are a few examples and may all require the use of a chopper pump.
Knowing the pumped media helps to choose the correct size of chopper pump. (Image courtesy of Vaughan Company Inc.)
