Various bearing types
An overview of common bearing usage.
Wheeler Bearing Company
Bearings are essential components in mechanical systems that require controlled motion while supporting loads and minimizing friction. Incorrect application can lead to premature wear, excessive heat, vibration and catastrophic failure. Understanding bearing types and their designed applications will increase equipment performance, longevity, efficiency and reliability.
The Role of Bearings
Bearings are designed to reduce friction and allow relative motion between components while constraining movement in a specific direction. Most commonly, they support a rotating element and maintain alignment while transferring loads to a stationary structure such as a casing or frame. This leads system designers and engineers to consider several factors when selecting a bearing. This includes load magnitude and direction, rotational speed, temperature, potential contamination, lubrication method, installation constraints and expected service life. No single bearing type is a universal fit. Correct application depends on matching the bearing characteristics to system requirements.
Radial Bearings
Radial bearings are designed primarily to support loads that act perpendicular to the axis of rotation. These loads are common in motors, pumps, fans, conveyors and gearboxes, where forces are generated by belt tension, gear mesh or component weight.
Ball bearings and cylindrical roller bearings are the most common radial bearing types. Ball bearings are best suited for moderate loads due to their point contact geometry, which reduces friction, and are suited for lighter radial loads like in-line drive applications. Cylindrical roller bearings, on the other hand, provide higher load capacity due to line contact between the rolling cylinders and raceways, making them ideal for heavier radial loads like belt-driven applications.
In radial bearing applications, proper shaft and housing fits are critical. Excessive interference can increase internal clearance reduction, raising operating temperatures, while insufficient fit can lead to creep and fretting. Designers must also account for thermal expansion, particularly in high-speed or high-temperature environments.
Radial bearings can tolerate limited axial loads in the ball configuration at around 20% or less of the radial load limit. However, they should not be relied upon as primary thrust-carrying components unless explicitly designed to carry a slight load. When axial loading requirements increase 20% or more, a thrust bearing configuration is recommended.
Thrust Bearings
Thrust bearings are specifically designed to support axial loads. These loads are common in vertical shafts, screw drives, gear systems, propellers and pumps where pressure differentials or mechanical geometry generate axial force. They come in ball and cylinder configurations and support lighter and heavier axial loading respectively.
Due to the nature of the load on thrust bearings, alignment is a critical aspect of functionality. Misalignment will apply uneven forces to the rolling elements and thrust faces. This will cause uneven wear and lead to rapid failure.
Thrust bearings are often paired with radial bearings in shaft systems. In these arrangements, one bearing is designated as the “locating” bearing, controlling axial movement, while the other allows axial float to accommodate thermal expansion. If radial movement cannot be corrected with a locating bearing, a self-aligning thrust bearing may be necessary.
Combined Load Bearings
In many pumping applications, bearings are subjected to both radial and axial loads simultaneously. Angular contact ball bearings and tapered roller bearings are commonly used in these situations. Their internal geometry allows them to support combined loading while maintaining stiffness and accuracy.
The orientation and arrangement of combined-load bearings, such as back-to-back or face-to-face configurations in a pumping application, influence system rigidity, axial displacement and load-sharing behavior. This allows for constant load axial load shift while maintaining system rigidity. Improper pairing or incorrect preload settings can introduce unwanted stress, reduce efficiency and cause early failure.
Fluid Film Bearings
Fluid film bearings differ fundamentally from rolling-element bearings. Instead of metal-to-metal contact, they rely on a continuous film of lubricant to separate moving surfaces. Load is supported by hydrodynamic or hydrostatic pressure generated within the fluid film. Journal bearings are the most common fluid film bearings and are widely used in turbines, compressors, large electric motors and internal combustion engines.
Fluid film style bearings offer several advantages, including high load capacity, low friction, excellent sound damping and a longer service life when properly designed and lubricated. Since these bearings operate on a noncontact design, an oil film carries and displaces the load at rates rolling elements would catastrophically fail under.
However, they require precise control of clearance, surface finish and lubrication conditions. Insufficient oil supply, contamination or improper startup procedures can result in boundary contact and rapid damage. Fluid film bearings require auxiliary systems to apply lubrication such as oil rings or pumps to ensure the proper amount of oil is in the bearing load zone for proper function.
Lubrication & Environment
Lubrication plays a critical role in bearing performance regardless of type. Rolling bearings typically use grease or oil lubrication, while fluid film bearings rely exclusively on oil. The lubricant must be based on the application needs and the environment it is operating in. Internal operating conditions, environmental conditions and cycle rate must be considered when specifying the correct lubricant.
Environmental conditions such as dust, moisture, chemicals and extreme temperatures influence bearing selection. Sealed or shielded bearings may be necessary in contaminated environments. Special bearing materials or coatings may be required in corrosive, high-temperature and variable frequency drive (VFD) applications.
Understanding the movement needs of a system is crucial to selecting the proper bearing. The bearing types discussed are a broad overview with many more application-specific designs being used elsewhere. Ensuring the needs—both internal and external—of the full application prior to bearing selection is imperative. Bearings are the linchpin of any system requiring motion, and understanding which bearing should be in an application and how to lubricate it properly will save time, headaches and money.
