I have received a lot of feedback from our readers on Part 1 of this article from the May issue of Pumps & Systems. One reader writes:
Dr. Nelik,
I read your interesting article, “River in the Desert, Fresh or Salt Water?” in the May 2018 issue of P&S magazine. I was surprised to read about plans for a major joint-venture project between Israel, Jordan, Syria and Palestine. It is good to hear that these countries (are working) together.
Assuming that the given pump flow rate and head values are close to best efficiency point (BEP) operation, a couple of different scenarios were run with the efficiency calculator.
1. Using the approximate United States customary unit equivalents to the metric values as given in the article:
2. Using U.S. customary unit equivalents to the given metric values:
In regard to the saltwater option shown in Image 1, on page 14, what is the purpose of the return tank? I may have missed a mention of this tank in the article.
Will the ~6-foot pump head be sufficient to move water to the upper end of the river in addition to overcoming friction losses through 3-kilometer (km) of suction/discharge piping? Pump and motor selections could be affected.
Lee Ruiz
Oceanside, California
Image 1. Concept view diagram (Images courtesy of the author)
Images 2. Modeling test rig, initial layout.
Images 3. A multidisciplinary team.
Friction loss in a pipe: The 150,000 gpm flowing through a 10-foot conduit results in approximately 4 ft/second velocity, and friction coefficient (looking up a Moody chart) is about 0.03 as a good initial estimate, resulting in hydraulic friction loss in a 3 km (about 10,000 ft) as:
This would need to be added to the initial head of 2 m (6 ft), to a total of now 14 ft, i.e., over doubling the power, and thus increasing electricity cost of not $150,000 per year, but nearly $400,000 a year. An excellent observation you made!
Thus, the equipment adjustments would be made to the initial rough starting estimate. This is a good example of the importance of accounting for both the elevation as well as friction system curve components.
Indeed, these are the steps that the project team will be further refining, and much work is still to be done. But the process has started and there are plenty of challenges to the mechanical, civil, environmental, biological and chemical engineering, not to mention the socioeconomic aspect.
I will keep you posted on the progress. In the meantime, keep on pumping!
- L. Nelik and P. Cooper, “Performance Characteristics of Multi Stage Hydraulic Power Recovery Turbines,” ASME Winter Annual Meeting, November 1984.
