HI Pump FAQs
by Hydraulic Institute
Q. What is the allowable pump/motor operating speed range when a variable frequency drive (VFD) is used?
A. VFDs are used to vary the speed of the pump in order to optimize system efficiency and/or process control. Adjusting the frequency applied to the motor allows the speed of the motor and pump to be changed, usually to a lower speed than the base revolutions per minute (rpm) stated on the motor nameplate or lower than the speed the pump would operate with utility power.
Operating a pump at reduced speeds is usually acceptable within a specified range, but operators must consider certain mechanical design features such as bearing lubrication and natural frequency interactions. Anyone considering reduced-speed operation should consult the pump original equipment manufacturer (OEM).
Operating the motor at lower speeds usually results in a reduction of the motor cooling system capability, because motor cooling fans produce less airflow over the motor at reduced speeds. Operators must ensure that the motor can withstand the added heat that is created by operating below base speed. The operating speed range should be defined and applied to motor capability requirements. In many cases, the pump and motor can be sped up to 10 percent above base speed without adverse effect, but operators should first consult the OEM to evaluate electrical and mechanical design considerations.
In rotodynamic pump applications, the load is governed by the pump affinity laws, which state that a change in torque is proportional to the square of the speed change and that change in horsepower is proportional to the cube of the speed change. This type of load is known as a variable torque load (VT). Most motors are capable of operating 10 times slower than the nameplate rpm of the motor (10-to-1 speed range, or turndown) when driving a rotodynamic pump.
Positive displacement pumps present higher relative loads at reduced speeds, which will have a more significant impact on the motor and drive. Most motors can operate with a 2-to-1 turndown speed range with this type of load, which is commonly considered a constant torque (CT) load.
For best results, define the load type and operating speed range in advance. Provide this information to the pump, motor and drive manufacturers and discuss it with them to ensure the motor and drive selection is the best fit for the pumping application.
For more information on VFDs, refer to HI's guidebook Variable Frequency Drives: Guidelines for Application, Installation, and Troubleshooting.
Q. What type of motor and motor enclosures are recommended for wastewater application pumps?
A. In wastewater applications, the pump driver can be a motor- or engine-driven unit. The most common pump driver in a wastewater treatment plant is an electric-powered induction motor. Engine-driven pumps are typically used in emergency or standby service when electrical power supply is not available. Synchronous motors can also be used, but they are normally provided for kilowatt requirements above 750 (horsepower requirements above 1,000).
Figure 5.1 Typical induction motorsFigure 5.1 Typical induction motors
The selection of a type of motor, the method used to start the motor and considerations for operating the motor are based on many factors. These include location, atmospheric designation of the location, operational conditions, size of the motor to be used, number of motor starts required and power availability.
The options for motor enclosures include open drip-proof (ODP), totally enclosed fan-cooled (TEFC) and totally enclosed non ventilated (TENV). When choosing the enclosure, consider the application and the area of use.
ODP motors are suitable for general industrial use in outdoor or indoor locations with relatively clean atmospheres and nonexcessive ambient temperatures. The ventilation openings of an ODP motor prevent interference with motor operation when liquid or solid particles less than 50 millimeters (mm) (1.97 inches) strike or enter the enclosure at an angle up to 15 degrees downward from vertical. In an open motor, air circulates freely through the motor for cooling. Openings are limited in size to prevent contact with hazardous internal parts. This provides some protection from drip, splash and falling objects. The motor is susceptible to moisture and contamination.
A TEFC motor is enclosed to prevent the free exchange of air between the inside and outside of the case, but it is not airtight. The exterior surface is cooled by an external guarded fan attached to the motor shaft, which circulates air over the frame housing. A finned cast-iron framed motor or a steel motor on a smaller motor frame is usually suitable for this type of enclosure. Because air does not pass freely through the motor, the TEFC enclosure protects the motor from harsh environments. They can be operated indoors or outdoors.
A TENV motor is a frame surface-cooled unit that is cooled by free convection. It is enclosed enough to prevent the free exchange of air between the inside and outside of the case, but it is not airtight. The motor is cooled by free convection and radiation only. A TENV motor is suitable for use in dusty, humid environments. In general, it is limited to low horsepower ratings or limited-time, duty-rated motors.
For more information, refer to HI's guidebook Wastewater Treatment Plant Pumps: Guidelines for Selection, Application, and Operation.
See other HI Pump FAQs articles here.
