by Hydraulic Institute
Q. What are the key considerations for upstream (suction) piping for single and multiple control-volume metering pumps?
A. Because of the characteristic pulsating flow of metering pumps (see Figure 7.8.7.1), where peak flow rates can reach three times the average flow, operators must carefully consider suction piping to ensure that it can deliver adequate fluid to the pump inlet.
  • The piping must accommodate the peak demands of the pump throughout its full range of operation, as well as prevent offgassing of liquids with high vapor pressure or dissolved gases. This can be accomplished by appropriately increasing the diameter of the suction piping and connections or by adding accessories to increase the flow of liquid to the pump inlet.
  • Long lengths of pipe, elbows, tees, strainers, valves and other accessories installed in the suction piping can decrease the net positive inlet pressure available (NPIPA) to an unacceptable level.
  • The pulsating flow in the system suction piping creates a pulse pressure that typically subtracts from system suction pressure. For example, a pump operating at 150 strokes per minute and 71 gallons per hour drawing water from 10 feet of half-inch schedule 40 pipe could subtract 10 pounds per square inch from the pump supply pressure. For shorter runs of pipe with minimum restrictions, a rule of thumb is to increase one pipe size above the discharge piping, or two pipe sizes above the pump’s suction connection. Long piping runs with multiple bends, elbows, restrictions and/or higher-viscosity liquids require larger-size piping.
  • The most frequent reason for technical support calls to pump manufacturers regarding problems with pump performance is suction piping that cannot supply the demands of the pump. To ensure adequate flow to the inlet of the pump, refer to NPIPA calculations outlined in ANSI/HI 7.8-2016.
Example of pulsing flowFigure 7.8.7.1. Example of pulsing flow (Graphics courtesy of Hydraulic Institute)
When connecting more than one pump head to a single suction manifold, operators must consider a number of issues. Suction manifold piping must accommodate peak demand of the pumps throughout its full range of operation, as well as prevent offgassing of liquids with high vapor pressure or dissolved gases. This is accomplished by appropriately increasing the diameter of the suction manifold and pump head connections or by adding accessories to increase flow of fluid to the pump inlet. The most important consideration is whether the multiple heads are part of a multiplex pump (multiple heads connected to a single motor or driver) or if the heads all have independent motors or drivers. In most cases, multiplex pumps are connected to a common manifold piping arrangement, driving these recommendations. The other option is to connect each pump head to its own suction line connected to the supply source.
In a multiplex where a single driver is used, if the pumps all operate from the same gear set or with multiple gear sets operating at the same stroking speed, industry best practices suggest that the drive mechanism for each individual pump head should be run out of phase (i.e. duplex pumps, 180 degrees; triplex pumps, 120 degrees; and so on). This staggers the peak suction requirements of the individual pumps.
Running several pumps from the same driver (motor) with proper phasing of the drive elements ensures this timing during all running conditions and the best suction flow characteristics as they relate to piping design.
When independent pumps, each with its own driver, are connected to a common suction line, or if the application requires multiplex pump heads operating in phase, operators must make allowance in the piping design in case all pumps simultaneously demand peak suction flow.
For more information on piping guidelines for control-volume metering pumps, refer to the new standard ANSI/HI 7.8 Control-Volume Metering Pump Piping Guideline.
Q. What are the requirements for good suction piping design for rotodynamic pumps?
A. Good suction piping design must eliminate air entrainment in the liquid, minimize friction loss, provide straight and uniform flow at the pump inlet, and avert excessive forces resulting from pipe strains at the pump.
Inlet flow disturbances such as swirl, unbalance in the distribution of velocities and pressures, and sudden variations in velocity can be harmful to a pump’s hydraulic performance, mechanical behavior and reliability.
Usually, the higher the energy level and specific speed of a pump and the lower the net positive suction head (NPSH) margin, the more sensitive the pump’s performance is to suction hydraulic conditions.
All inlet (suction) fitting joints should be tight—especially when the pressure in the piping is below atmospheric—to preclude air leaking into the fluid. Any valves in the inlet line should be installed with stems oriented to minimize the possibility of air accumulation. For pumps operating with a suction lift, the inlet line should slope constantly upward toward the pump, with a minimum slope of 1 percent (see Figure 9.6.6.3). For most pumping systems, a shutoff valve should be installed in the suction piping for system isolation.
Pages
