11/10/2014
Q. What is a regenerative turbine pump? A. Regenerative turbine pumps are characterized by a low flow rate and high head. They use peripheral or side channel vanes or buckets that are manufactured with a rotating impeller to impart energy to the pumped liquid. Shearing action causes the liquid to acquire a spiral rotation as it passes from the buckets of the rotating impeller into the stationary side channels. The buckets are radial channel cavities separated by teeth, also called vanes or webs. Pressure increases uniformly from the pump inlet to the discharge. For more information on rotodynamic pumps, see ANSI/HI 1.1-1.2 Rotodynamic Centrifugal Pumps for Nomenclature and Definitions.
Figure 1.1.3d. Rotodynamic pump types: regenerative turbine (Graphic courtesy of the Hydraulic Institute)- Bearing housing vibrations can cause fatigue fracture of instrumentation or pipes.
- Baseplate vibrations can occur.
- Fatigue fracture of the tie bolts in multistage segmental pumps or joining elements in the stage casings of barrel pumps may result.
- The pressure pulsations generated by the pump can lead to standing waves (acoustic resonances) in the system that may upset the control system, induce pipe vibrations, cause breakage of instrument lines or affect resonances with other components.
- Alter the resonant piping.
- Change the pump speed.
- Change the internal design characteristics of the pump.
- Insert a pulsation damper on the pump/piping system.
HI Pump FAQs® is produced by the Hydraulic Institute as a service to pump users, contractors, distributors, reps and OEMs. For more information, visit pumps.org.
