Coupling Considerations for Pump Applications
Written by:
Bill Holtz, Rexnord Industries
A flexible coupling's primary functions are connecting two shafts, transmitting power from a driver shaft to a driven shaft and accommodating the misalignment between them. With only these requirements, it would appear the coupling selection could be narrowed down to one or two types. Unfortunately, it is not that easy. All flexible couplings accomplish the above three functions, but they do so with varying degrees and attributes. It is within these secondary coupling attributes that the best coupling selection is separated from the fair, poor or even disastrous ones. No single type of coupling will be perfect for all applications.
In industrial pump applications, both lubricated and non-lubricated couplings are used. Some common coupling options include disc, shear jaw and bonded tire non-lubricated designs, as well as grid and gear style lubricated couplings.
Coupling Attribute Comparison
In the selection process, coupling manufacturers help users make selections based on general requirements such as torque, speed shaft sizes and shaft gap. To select the best coupling for an application, the requirements of the application must be reconciled with the performance attributes of the specific coupling. Although there are many attributes to consider for the five couplings mentioned, we will compare the following coupling attributes-misalignment, speed, torsional stiffness, weight, torque density, temperature and generated thrust forces-for a 100 hp, 1,750 rpm centrifugal pump with a 5 in shaft gap between the motor and the pump.
Misalignment
For purposes of our discussion, the misalignment levels referenced here are operational limits, which are the maximum levels of misalignment the coupling can accommodate before experiencing shortened life (see Figures 1A, 1B and 1C).
Figure 1A
Figure 1B
Figure 1C
 Figure 1A (top), Figure 1B (middle), Figure 1C (bottom)
In addition, coupling manufacturers are typically able to provide installation limits, which are lower misalignment values than operational limits. Aligning equipment at or below the installation limits will help reduce equipment vibration and extend the life of other system components like bearings and seals. It is important to remember that using a high misalignment coupling such as an elastomeric one to compensate for misalignment is no excuse for poor alignment practices. Although the coupling may be able to tolerate the misalignment, other components of the pump system may not fare as well.
Axial misalignment, although often overlooked, can be important where thermal growth is an issue or where sleeve bearing motors, herringbone gearsets and other axially sensitive equipment is involved. Gear and tire-type elastomeric couplings have relatively high axial misalignment capacity, but axial forces may result from this movement. Thrust forces will occur in tire-type elastomeric couplings as a result of axially stretching or compressing the elastomeric element. In the case of gear couplings, this effect may result from forces required to slide the coupling under load.
Speed
Where high coupling speed ratings are required, a disc or gear coupling is the best choice due to compact size and inherently balanced designs. In addition to the relatively high speed ratings of the standard designs, only these two coupling types can be dynamically balanced for increased speed ratings (see Figure 2).
Figure 2
Figure 2
An added advantage for disc couplings is low potential unbalance, which makes their balance more repeatable. In other words, the balance achieved on the balance machine with a disc coupling will have the best chance of being repeated in the field.
Torsional Stiffness
Each type of coupling has unique stiffness characteristics that can be used to meet application requirements  (see Figure 3). In applications such as an indexing conveyor or a paper machine drive, where the drive output and input need to be closely in phase, a torsionally stiff coupling like a disc or gear coupling may be the better choice. Disc couplings, although not as stiff as gear couplings, offer the benefit of no backlash. To reduce the severity of shock loads, elastomeric couplings can be used to provide softer starts than a gear or a disc coupling. Many of these designs can exhibit torsional windup of up to 6 deg at rated torque.
Figure 3
Figure 3
Torsionally soft couplings may also be employed to avoid vibration from operating at system natural frequency, either by shifting the system natural frequency or by dissipating the vibrational energy associated with system resonance. Grid couplings are a good compromise of soft and stiff, offering the strength of steel and the softness of an elastomer. This coupling design can reduce transmitted vibration by about 30 percent compared to a gear or disc coupling.
Pages
Cahaba Media Group
See also:
Upstream Pumping
