A new air distribution system enables air-operated double-diaphragm pumps to set a new standard in process optimization.
by Carl Glauber, Wilden
Pumps & Systems, July 2013
Concerns regarding the amount of energy that is consumed—and potentially wasted—by industrial facilities in the U.S. officially reached the highest levels of the federal government in August 2012, when President Barack Obama signed an executive order titled “Accelerating Investment in Industrial Energy Efficiency.” The executive order stated that the industrial sector accounts for more than 30 percent of all energy consumed in the U.S. It explains how increased industrial energy efficiency can provide benefits to manufacturers, utilities and consumers, while simultaneously improving the nation’s energy system, American manufacturing competitiveness and job creation.
The executive order acknowledges what the operators and managers of industrial manufacturing facilities have known for more than a decade: the modern-day definition of a successful industrial manufacturing operation does not only satisfactorily meet production quotas. As utility costs steadily rise and increasing environmental consciousness has become a priority, a successful industrial operation is one that delivers the required production rates in the most cost- and energy-efficient way and in an environmentally friendly manner.
Pumps, which are the second-most widely used machines in the world, play a critical role in worldwide industrial operations and many different industries—from chemical production and mining to water/wastewater treatment and hygienic applications. According to the U.S. Department of Energy’s Office of Energy Efficiency and Renewable Energy, pumping systems account for between 27 and 33 percent of the total electricity used and consumed in the industrial sector.
Recognizing the importance of pumping systems in industrial applications, The Hydraulic Institute has commissioned the writing of Optimizing Pumping Systems: A Guide for Improved Energy Efficiency, Reliability & Profitability, which provides instruction on how facility operators can recognize inefficient energy usage in their operations and the steps they can take to remove these inefficiencies. Facility operators must be fully aware that the initial purchase and installation cost of a new pumping system is generally only a small part of the total cost of ownership. During the 15 to 20 years that a typical pumping system is in operation, the routine costs of energy, maintenance and other recurring expenses are the primary components of total lifetime cost. Therefore, maximizing efficiency when designing and operating a pumping system is in the best interest of the facility, its customers and the environment.
Pump manufacturers realize the their products’ importance in the industry and have worked to design and develop pumping equipment that satisfies the increased need for energy efficiency and reduced operating costs. This article illustrates how a new air distribution technology can help minimize air consumption and improve the overall efficiency of reciprocating positive displacement air-operated double-diaphragm (AODD) pump technology that is used in many of the world’s industrial, liquid-handling applications.
AODD pump savings
The new ADS allows specific AODD pumps to achieve up to a 60 percent savings in air consumption when compared to other AODD pump technologies while providing more product yield per standard cubic foot per minute.
The Challenge
Invented in 1955, AODD pumps were specifically designed for use in utilitarian liquid-handling and transfer operations. During the next six decades, AODD pump technology has gained a well-earned reputation for outperforming other positive displacement pump styles—such as lobe, gear and progressive cavity—in the demanding liquid-transfer applications. That is because the design characteristics of AODD pumps enable them to meet most flow requirements and require little maintenance while also having the ability to:
  • Run dry
  • Maintain a suction lift up to 30 feet (9 meters)
  • Withstand deadhead conditions without damage
  • Operate while completely submerged and pass solids up to 13/8 inches (35 millimeters)
While the operation of an AODD pump has basically remained constant for the past 60 years, improvements have been made in the pump’s air distribution system (ADS) that address its rate of air consumption in relation to the product flow rate and how much air can be wasted during the pumping cycle, with that wasted air resulting in an added cost for the end user. While these savings are important for end users, they are actually modest when compared to the total volume of air used for these pumps.
An opportunity remains for more significant savings. During the time period from the end of each stroke to the completed shift of the valve, the air is allowed to “overfill” the air chamber without any corresponding displacement of fluid. The rate of this “overfilling,” which is defined as wasted compressed air, can be more adequately controlled. Attempts at improving the ADS in order to eliminate overfilling have included the incorporation of a control dial that “sets” the pump’s operation at a point that optimizes both air consumption and flow rate. However, these control dials need to be manually adjusted by the end user after identifying the point in which air usage and flow rate are both at their most efficient, which can be time-consuming and place an undue burden on the end user.
Pages
