Frequency Detuning in Vertical Pumps
Written by:
Carlos Moreno, Flowserve
Detuning devices solve high vibration problems in power station water circulating pumps.
Mechanical resonance—the buildup of a large vibration amplitude when something is excited at its natural frequency—comes in many forms. In its most desirable state, it occurs in music. Instruments and acoustics are finely tuned to produce dramatic and beautiful resonant effects. In its most undesirable state, mechanical resonance has extremely dramatic effects.They can cause bridges, structures and machinery to break or malfunction, resulting in dangerous and expensive failures.
Engineers work diligently to fine-tune mechanical structures and machinery to reduce or eliminate the effects of mechanical resonance before construction or installation. Engineers must account for the following factors when designing pumping systems to avoid mechanical resonance:
  • Operating speed
  • Foundation stiffness characteristics
  • Drive reed critical frequency
  • Bearing span
  • Bearing damping coefficients
  • Bearing stiffness coefficients
  • Drive mass and distribution
  • Pump mass and distribution
  • Pump fluid
  • Geometry of the rotor and structural components
When assumptions are wrong or the actual installation does not mirror the engineering models, the potential for mechanical resonance could exist if the system’s actual natural frequency is too close to the operating speed. Issues do arise, often from unexpected foundation conditions or inaccurate drive reed critical frequency data.
Natural Frequency in Pumps
A mechanical system’s natural frequency is a function of its weight and stiffness, most commonly expressed as:
ωn = √(k/m)
Where
ωn = natural frequency
k = stiffness
m = mass
For horizontal pumping systems, the solution to resonance issues has generally involved simple modifications that increase system weight, reducing natural frequency as a result and creating an adequate margin from the operating speed.
Resonance issues can be much more difficult to address with large vertical circulating water pumps. Typically found in power generation, steel manufacturing, water intake and flood control applications, these massive, expensive pump installations can be difficult and costly to modify once installed. Because of these difficulties, engineers are forced to employ more sophisticated techniques that alter system stiffness as a means of changing natural frequency once pumps are installed.
Often, this can be accomplished by adding frequency detuning devices to the pump system structure. In principle, the addition of these devices reduces system stiffness, lowering its natural frequency away from potential points of excitation. While this practice has been around for decades, advances in testing and modeling techniques have made design and application of detuning devices extremely reliable, avoiding the unnecessary and costly trial and error previously associated with this technique.
Frequency Detuners for Vertical Pumps
Axial and mixed-flow vertical circulating water pumps (see Figure 1) are wet-pit installations with these main components:
  • Suction bell
  • Rotor assembly (impeller, shaft, bearings, couplings and drive rotor)
  • Column
  • Discharge head
  • Drive (not shown)
In this type installation, one of the easiest and most inexpensive places to affect a change in natural frequency is at the interface between the discharge head and the driver. A detuning device for this type pump system consists of two carbon steel plates (sometimes called spring plates) mounted between the driver flange and the pump driver support flange of the discharge head. A gap between the cantilevered portions of these plates adds flexibility to the system—like a pair of springs acting in series—reducing system stiffness. To illustrate the engineering and application of detuning devices, consider the following circulating water pump application at a Midwest U.S. power station.
Figure 1. Typical vertical circulation pump
Frequency Detuning in Practice
Despite careful engineering, two vertical circulating water pumps exhibited higher than expected vibration levels shortly after installation (see Figure 2). Engineers performed thorough vibration analysis on both units, revealing high amplitudes in both systems, the most severe being in Unit 1B. Measurements for Unit 1B are shown in Table 1. To identify and confirm a resonance issue, consulting engineers engaged in the following field testing and analysis.
Figure 2. Original pump installation at the power generation plant
Impact Testing with a Calibrated Hammer
In this method, engineers strike the pump system at multiple locations using an instrumented hammer and use a vibration sensor and a vibration analyzer for measurement. This method of striking a system with a mass and measuring its response is common for determining natural frequencies in mechanical structures. Best practice requires that the impact testing take place at multiple locations on the structure to identify several resonant frequencies. This test must be performed with the pumping equipment off. The recorded first and second natural frequencies are shown in Table 2.
Pages
Cahaba Media Group
See also:
Upstream Pumping
