Q. How should measurement uncertainty be accounted for when running a hydraulic acceptance performance test of a rotodynamic pump? A. Measurement uncertainty depends on the residual uncertainty...
Choosing the right fluids and following best practices for maintenance can significantly enhance system reliability.
Function fitting and iterative numerical techniques inside a spreadsheet
Compression packing used as a valve stem seal requires a compressive load. The appropriate compressive load can be accomplished by the most common method—to compress the packing by a fixed...
This article will discuss a case of how measuring vibration can help detect cavitation issues. It will also show how this can relate to a bigger problem at the plant. Sometimes a proposed change of...
These pumps prove their worth in critical handling operations.
While global energy demand fuels source diversification, coal is still king.
Painful Katrina lessons inspire improvements that helped protect New Orleans from Hurricane Isaac.
Pump companies work quickly to clean up Sandy destruction.
Proven concepts together with new technologies battle the energy crisis.
Memorization and learning are two different things. As I look back on my own education—formal and real life—most of the facts and figures that I memorized are long gone. Even today, routine...
