Skip to main content
Pumps & Systems Menu
Pumps & Systems
Pumps and Systems
Menu
Search
Subscribe
  • Topics
    • Pumps
    • Seals
    • Bearings
    • Valves
    • Motors & Drives
    • Instrumentation
  • The Latest
    • Browse by Issue
    • Podcasts
    • News
    • Events
    • Digital Edition
    • Columns
    • Departments
      • Back to Basics
      • Efficiency 101
      • HI Pump FAQs
      • Maintenance Minders
      • Market Analysis
      • Motors & Drives
      • Sealing Sense
      • Submersible Solutions
  • Learning Opportunities
    • White Papers & Case Studies
    • Webinars
    • Videos
    • Training
  • Connect
    • About Us
    • Contact Us
    • Advertise
    • Subscribe
Subscribe to Pumps & Systems
Subscribe Now and Get:
Breadcrumbs
You are here:
  1. Home
August 2014
Expansion Joint Selection Optimizes Piping Systems
Expansion Joints
Different material and design combinations offer application-specific advantages.
System Selection Crucial for Long Wastewater Pump Life
Pumps
Driving down investment, energy and maintenance costs translates into big savings throughout an installation’s lifetime.
Pumps
Close Inspection Solves High Thrust Bearing Temperature Problem
Careful analysis identified the issue with this multistage, oil transfer pump.
Treated Carbide Surfaces Enhance Running Performance
Pumps
This technology self-lubricates, reduces friction and performs in wet or dry operating conditions.
Understand Specific Speed & Disc Diaphragm Pump Coupling
Pumps
System Validation & Troubleshooting
Smart Air Distribution Systems Upgrade
Traditional AODD Pump Technology
Pumps
Head-to-head comparisons show decreased compressed air use and enhanced flow.
Three-Phase Voltage Variation & Unbalance (Last of Two Parts)
Motors
Reducer Fittings Decrease Pipe Size to Avoid Failure (First of Two Parts)
Piping
Design of the pump inlet piping can protect overall operation.
Seals
Select Seals That Meet the Chemical Challenges of HPLC Pumps
Abrasive processing and wide temperature range are some of the pumping difficulties for high-performance liquid chromatography.
Energy Efficient Vertical Turbine Pumps Promote Sustainable Mining Efforts
The computational fluid dynamics process advances highly efficient pump designs for difficult applications.
The Differences Between Submersible & Immersible Motors
Motors
How do end users choose, and what are each type’s ideal applications?
Simplify the Equipment Selection Process
Pumps
Seals
The Right Seal & Lubricant Combination Can Prevent Bearing Contamination
Lip and labyrinth seals provide protection in harsh oil and gas applications.
Pushing Fluid Machinery Leads to Frequent Failures (Second of Four Parts)
Centrifugal Pumps
This four-part series explains the reasons behind repeat pump failures and uses a real-world field example involving boiler feedwater pumps.
Specific Pump & Valve Features Serve Liquefied Natural Gas Applications
Pumps
LNG benefits have increased the demand for this cleaner burning fuel and associated production and distribution equipment.
6 Refinery Pump Maintenance Tips
Pumps
Outside lubrication experts help improve protocols and minimize downtime.
Wall Street Pump & Valve Industry Watch: August 2014
Pumps
Intelligent Monitoring Delivers Real-Time Pump Performance Data
Pumps
An energy efficiency and reliability study helped one plant save $1 million annually by avoiding downtime.
Canned Magnetic Bearings Minimize Corrosion in Oil & Gas Processing
Bearings
Safely immerse motor compressors in process gas without risking costly damage.
Dewatering Pumps Handle Sand Slurries in Post-Hurricane Recovery
Pumps
Reconstruction and infrastructure upgrades require pumps made from durable materials.
Pumps
Education & Service Required to Maintain Machinery
To master the use of pumps and lubrication systems, proper training is essential.
SubscribeSubscribe to August 2014
Digital Partners
Trending
Pumps
Industry Veterans 2025: Al Hubbard
Hubbard shares wisdom gained over his 41-year career.
Pumps
How Flow Meters Benefit Brewery Efficiency
Applications, requirements and types of flow meters used in beer brewing.
Pumps
Ask the Engineer: July 2025
7 industry experts share career highlights and the best advice they’ve received from a mentor.
What Is Pump System Certification Level 1?
An in-depth look at the Hydraulic Institute’s new certification training program.
From Our Partners
Vertical Angleflow Pumps Help Protect Large Community
The pumps play a pivotal role in wastewater treatment for Springfield, Illinois.
Pentair Fairbanks Nijhuis
Advantages of Sliding Vane Magnetic Drive Pumps in Dry-Run Conditions
These pumps offer an alternative to centrifugal and gear pumps, as well as mag-drive pumps.
Blackmer
Strategies for Effective HVAC Pump System Retrofits
Improving efficiency and performance while reducing maintenance and life cycle costs.
Pentair Aurora
Maximizing Product Recovery, Process Safety & Profit With Eccentric Disc Pumps
This webinar will explore the unique working principle of eccentric disc technology and its advantages over other positive displacement pumps.
Mouvex
The Hidden Costs of Pump Failure & How to Avoid Them
This session will unpack the full cost of pump-related downtime, and also share tips for preventing these issues using proven best practices.
Chesterton
Browse Our Library
Topics
Pumps
Seals
Bearings
Valves
Motors and Drives
Instrumentation
News
Magazine
Events
Webinars
White Papers
Podcasts
Advertise
Customer Service
Subscribe Now!
Connect with Us
  • Home
  • Topics
    • Pumps
    • Seals
    • Bearings
    • Valves
    • Motors & Drives
    • Instrumentation
    • Pump Industry Insider
    • Compressors
    • Filters
    • Piping
  • Magazine
    • Browse by Issue
    • Digital Edition
    • Market Analysis
    • Columns
      • Amin Almasi
      • Gary Dyson
      • Jim Elsey
      • Joe Evans
      • Dominik Fry
      • Ray Hardee
      • William Livoti
      • Lev Nelik
    • Departments
      • Back to Basics
      • Efficiency Matters
      • Flow Meters
      • Motors & Drives
      • Sealing Sense
      • HI Pump FAQS
  • Training
  • Resources
    • Digital Edition
    • Podcasts
    • From Our Partners
    • White Papers
    • Webinars
    • eBooks
    • Sponsored Videos
    • News
    • Events
    • SWPA Training Center
    • Manufacturer Directory
  • Subscribe
  • Customer Service
  • About Us
    • Editorial
    • Advertise
    • Subscribe
    • Contact Us
    • Data Privacy
